canam1991 2 #1 Posted March 27, 2011 i just put my tiller on my 520 and when i put the cable on there was no lift tube on it like my 312 had. is it missing it or does it route some way i don't see? Thanks Share this post Link to post Share on other sites
zieg72 209 #2 Posted March 27, 2011 The lift tube for the cable on a hydro is different. The lift cable is longer as well... Been there done that. PM me your email address and I can send you pictures of how I made the lift cable work on mine if you are interested. Share this post Link to post Share on other sites
mcwh1950 2 #3 Posted March 27, 2011 The lift tube for the cable on a hydro is different. The lift cable is longer as well... Been there done that. PM me your email address and I can send you pictures of how I made the lift cable work on mine if you are interested. zeig 72 Under canam1991 signature just click on his email and you will be able to email him. Yes I renember about you trouble with you tiller you had. Share this post Link to post Share on other sites
canam1991 2 #4 Posted March 28, 2011 so the tube off my 89 312h wouldn't work or and older 141h c series? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted March 28, 2011 As long as the "donor" tractor has an Eaton hydro, the tube will work. ( "S" shaped tube) The cables are actually the same length between the hydro and gear-drive models too - the hydros just use a longer clevis at the front of the cable to make up the difference. Here's a link to the IPL for a clevis hitch that lists everything: #85518 hitch IPL Share this post Link to post Share on other sites
Shuboxlover 482 #6 Posted March 28, 2011 If you need the tube and corresponding clamp, let me know, I have one I would sell you reasonably. Tyson Share this post Link to post Share on other sites
zieg72 209 #7 Posted March 28, 2011 Here is what I had to do to get the cable off a C165 to work on my 520H Attached Image Share this post Link to post Share on other sites
