snowbelter 0 #1 Posted March 26, 2011 hey fellas would a tiller from a raider 12 not sure what year fit and run on a 93 520h? Share this post Link to post Share on other sites
farmer 1,081 #2 Posted March 27, 2011 I'll take a punt and say yes, just based on the fact they are both horizontal shaft engines and design really hasn't changed much over the years. You will need the mid mount idler and the rear axle bracket, but to be sure try to get the tiller model # and check it out Good luck. :D Share this post Link to post Share on other sites
mavfreak 11 #3 Posted March 27, 2011 If the raider has the atch a matic then it should but if it doesn't some modifications will be needed! Share this post Link to post Share on other sites
Kelly 1,036 #4 Posted March 27, 2011 Like Heath said if the Raider has the attach o matic set up it SHOULD work, but it would be best to get the model no. off the tiller or pictures, if it is the old style tiller it can be made to work. Share this post Link to post Share on other sites
