rockinhorse 45 #1 Posted March 25, 2011 I have a b-80 3 spd trans. Trying to change trans pulley,but can't find pulley like wheel horse. w/h hub is 1 1/4"thick with set screw in the middle of hub. All the pulleys i have found set screw is offset. Where do you guys get pulleys when you change speeds on your tractors? I have put a bigger pulley on motor already. Any ideas? thanks karl flat rock, in. Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #2 Posted March 25, 2011 Drill & tap another set screw hole at the bottom of the "V" in the new pulley. Make sure you use a quality steel pulley and not one of those cheap Chiwanese stamped & welded pulleys. Share this post Link to post Share on other sites
wheelhorse656 20 #3 Posted March 26, 2011 Make sure you use a quality steel pulley and not one of those cheap Chiwanese stamped & welded pulleys. I hate those pieces of Crapp! :thumbs: Share this post Link to post Share on other sites
JC 1965 1,549 #4 Posted March 26, 2011 :D Hello and :thumbs: Share this post Link to post Share on other sites
