Countdown To Christmas!
rockinhorse
transmission pulleys
rockinhorse
I have a b-80 3 spd trans. Trying to change trans pulley,but can't find pulley like wheel horse. w/h hub is 1 1/4"thick with set screw in the middle of hub. All the pulleys i have found set screw is offset. Where do you guys get pulleys when you change speeds on your tractors? I have put a bigger pulley on motor already. Any ideas?
thanks
karl
flat rock, in.
TT
Drill & tap another set screw hole at the bottom of the "V" in the new pulley.
Make sure you use a quality steel pulley and not one of those cheap Chiwanese stamped & welded pulleys.
wheelhorse656
I hate those pieces of Crapp! :thumbs:
JC 1965
:D Hello and :wh: :thumbs:
