Giles 2 #1 Posted March 19, 2011 Thought some of you might want to see my setup---It is a 26 Gallon tank that I bought for her 20 years ago--- Share this post Link to post Share on other sites
Sparky-(Admin) 24,635 #2 Posted March 19, 2011 Hows the steering when the tank is full? And what do you spray with it? Mike......... Share this post Link to post Share on other sites
Giles 2 #3 Posted March 19, 2011 Hows the steering when the tank is full? And what do you spray with it? Mike......... Like power steering A little light in the front when tank is full, just have to be carful when going uphill forward or sideways on incline. I have sprayed hundreds of gallons but with throttle set at just above idle, there is little chance of a front end lift. Been CAREFUL and LUCKY so far. :thumbs: Share this post Link to post Share on other sites
wheelhorse656 20 #4 Posted March 19, 2011 Nice set up!!!!! :thumbs: Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted March 19, 2011 26 gallons of water=217 pounds. Share this post Link to post Share on other sites
Giles 2 #6 Posted March 19, 2011 26 gallons of water=217 pounds. And I weigh about that I have been using this setup for many years---only a TOUGH machine could still be going :thumbs: Share this post Link to post Share on other sites
Coadster32 793 #7 Posted March 19, 2011 Nice setup you have there. :thumbs: Share this post Link to post Share on other sites
jtmoyer 1 #8 Posted March 19, 2011 im planning on putting one together together today on the back of the 416, just wont look as nice. Share this post Link to post Share on other sites
Giles 2 #9 Posted March 19, 2011 im planning on putting one together together today on the back of the 416, just wont look as nice. I would suggest that you make a strong framework for support, since there is a lot of weight hanging off the back. My framework serves two purposes. My rear fenders were cracking so I removed the assembly and made a support frame for the fender assembly to rest on. I used 1/8 x 1 1/2 angle iron with a section across the back to hold the sprayer frame. I then supported the frame to the hitch. You might want to view my other photos under-- "My Original 1980 C175" Share this post Link to post Share on other sites
VinsRJ 723 #10 Posted March 19, 2011 Nice set-up, you must have a good size yard? or just a lot of weed? Share this post Link to post Share on other sites
