6wheeler 675 #1 Posted March 18, 2011 I have a C-120 model# 71-12K801, I don't know what year it is. It came with a deck that wasn't on the tractor. The PO mainly used it as a snow blowing tractor so the deck got very little use. I cannot read the model # on the deck (the label is 2/3rds missing). I measured it across the blades and it is 40 1/2 inches. I believe it is the original deck. It is in mint condition, it is even nice and red underneath. The only things wrong are the belt and the wheels are completely dry rotted. Are all the wheels the same size? Would this be considered a 40" deck then? Without a model# I don't know how to try to order them. :thumbs: Share this post Link to post Share on other sites
mavfreak 11 #2 Posted March 18, 2011 If you can post a picture that would help. If you measured across the blades that gives you the width of the deck witch means its a 40". Hopefully someone else can get you the belt length cause I don't know it off hand. You can probably pull off the wheels and go to the hardware store or a TSC and match them up. Try posting a picture cause it can tell us alot and someone may even be able to give you a model number. You can post an add here for the wheels and rollers. Share this post Link to post Share on other sites
stevasaurus 23,619 #3 Posted March 18, 2011 Pat...your tractor is a 1977. If the deck is original...it is either a 42' side discharge #75-42ms01 or it is a 42" rear discharge #75-42mr01 there is no 40" deck that I can find, and you are measuring more then the 36" deck would measure. :thumbs: Share this post Link to post Share on other sites
