mavfreak 11 #26 Posted March 25, 2011 Len it might be worth your while to get a photobucket account. its free and easy to post pictures to the forum. http://www.wheelhorseforum.com/index.php?...indpost&p=10843 Try looking aat this thread to help with posting. Good luck! Share this post Link to post Share on other sites
Len Haduck 0 #27 Posted March 25, 2011 Hi Heath, Some info. I rough measured the holes in the deck and it looks like the lift assembly would match up. I think I would need a new double pulley for the belt drive, but honestly I know very little about this. The deck model is a 42XR01 and the photobucket link is below to copy and paste. I would be grateful for any info. or ideas you may give me. I live in cental pa and have been looking for a doner deck but have been unsuccessful. Missed on a very nice rd 42 today by minutes! http://s737.photobucket.com/albums/xx11/Le...mview=slideshow thanks, Len Share this post Link to post Share on other sites
mavfreak 11 #29 Posted March 25, 2011 Ok len your deck is set up for the atch-O- Matic You need to put all the frame work back onto it if you have it. And yes it does appear to be missing the double pulley. so at this point I think you should start another thread and we'll get others here involved with this and get you going. By the way your deck doesn't look like its in bad shape just looks like a little love is all it needs. And if the bearings are good in it you have the most expensive part and thats the deck so lets see what we can do Share this post Link to post Share on other sites
Kelly 1,033 #30 Posted March 25, 2011 That deck is for a vert shaft tractor, you will need to trim some of the front braket off, and add the top hanger, all the correct holes sould be there to mount it, not sure on the rear cross bar what will need to be changed, and you will need the double pulley, I have a B-111 with that same deck. Share this post Link to post Share on other sites
WH854 45 #31 Posted March 26, 2011 Here is a break down of that deck, just put this model # in( 85-42XR01) https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Maybe give you an idea what you will need Chas Share this post Link to post Share on other sites
Len Haduck 0 #32 Posted March 26, 2011 I'll get looking. I need everything! I really appreciate the info. I figured the pulley would need replaced. Do you know if the double pulley is standard throughout the line or should I be looking for one from a 42 in deck? I will also begin the search for the lift mechanism. I have a 36 in deck I could probably pilfer it from but hate to pillage anything from a working deck. Len Share this post Link to post Share on other sites
WH854 45 #33 Posted March 26, 2011 what model tractor are you putting this deck on? if it is a horizontal shaft engine you will need parts for a deck like (05-42MR01) look here!! Put that Model# in https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Chas Share this post Link to post Share on other sites
Len Haduck 0 #34 Posted March 26, 2011 Going on a 314-8 Share this post Link to post Share on other sites
WH854 45 #35 Posted March 26, 2011 (21-14K801)1985 314-8 Put this model # 21-14K801 Here it will tell you a lot about your Tractor https://homeownersolutions.toro.com/portal/...ductDetailsPage Chas Share this post Link to post Share on other sites
Len Haduck 0 #36 Posted March 26, 2011 Appreciate your help. Also started a new thread to try and scrounge up some of the parts. Have a great weekend! Share this post Link to post Share on other sites
