RyanM84 0 #1 Posted March 11, 2011 Has anybody posted a "HOW TO MAKE TILLER LIFT CABLE"??? Cause I just bought a 1975 Tiller model# 7-1252 for my 91 312-8 and it didnt come with a lift cable. So I called the wheel horse dealer and he said the cable is going to be $39.00 and I was like damn and he also said the whole lift assembly with buying all the parts can be up to $250-$300 at Jacks Wheel Horse Sarver, Pa. I was like wow almost the price of the tiller. Soooo I thought hell i can make one but I havent seen a how to make page yet...... They seem pretty simple to make. I might have to rip my dads tractor apart to see his lift cable. So please Help :thumbs: Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted March 11, 2011 If you just want a lift cable yes buy some cable at a hardware store with feruls (sp) and cable clamps, most newer tractors have the tube just no cable, to do it like factory on your tractor there is a rockshaft that goes under the fender, they can get pricy, I've sold a few for $175 plus complete, I might still have one complete set up if your interested. Share this post Link to post Share on other sites
B-8074 20 #3 Posted March 11, 2011 It's pretty easy like Kelly said. Just double check to see if the tube is there for the cable to run through. And Kelly, Do you know the model # for the rear rock shaft? Share this post Link to post Share on other sites
IthacaJeff 151 #4 Posted March 11, 2011 Ryan: Last fall I made a lift cable for my 310-8 with clevis (sleeve) hitch in order to lift my single bottom plow. I used 1/8" steel cable with the typical thimble and cable clamp mechanisms; cost about $10 at the local Agway including some small clevis hitches. Made a loop on one side, attached to the lift lever according to a parts diagram, then snaked the other end of the cable through the cable tube that runs on top of the tranny. Lifted the sleeve hitch as high as it would go and set the length of the cable (with loop on end and a small clevis hitch) to this length. It was a pain to tighten the cable clamps as they were under the seat, but it got done. I wrapped a bunch of duct tape around the cable clamps and cable end to prevent these from catching on the seat support. I cut the cable with a good set of tin snips. All this took me about 45 minutes. Is crude, but is works. Next week I'm going to come up with a more effective solution than the duct tape, like a piece of hose. Lifted the bottom plow fine. As you can tell, I have no rockshaft under the seat, but the thing works. I'll remove the sleeve hitch next week and set the cable for my tiller. Will likely need to add chain links to set the right length. This all assumes I can get the tiller refurbished in time! I also have a 3/16' cable that I am working on to make a better lift, but it is a low priority at this time. Jeff in Enfield NY Share this post Link to post Share on other sites
RyanM84 0 #5 Posted March 12, 2011 Ok I have the tube that goes over the tranny that is standard. But the "ROCKSHAFT" ok is that the part that the chain from the tiller attaches too and the cable attaches also to and this part is like a rocking arm that attaches some where under the seat??? Thanks Ryan Share this post Link to post Share on other sites
mcwh1950 2 #6 Posted March 12, 2011 Ryan. I do not know if this will help you or not. Go to this web page. https://lookup3.toro.com/request/request.cfm. put in 79370 for serial number and 3999999 for a model number and you will be able to download a manual for a tiller. 1 Share this post Link to post Share on other sites
RyanM84 0 #7 Posted March 12, 2011 Now thats what im talking about!!! BRAVO BRAVO!!! a freaking owners manual too bad its black and white and my poor young eyes cant see the pictures very well. hahahaha Thanks So much I needed that. Now I need some parts.... Share this post Link to post Share on other sites
can whlvr 994 #8 Posted March 12, 2011 i have a tiller on my 414 and u dont have to have a rock shaft,it may work better though,ive never had one Share this post Link to post Share on other sites
