squonk 44,876 #1 Posted March 5, 2011 Just picked up this 36" blower today. Needs some TLC but everything turns free. It's got a blowout patch job but it seems sturdy and it's got a cobbed chute cable but it works. It came with the lift rod and flag and that's worth what I paid alone It's missing the drive chain. What size and length is needed and does anyone have a pic of the chain routing? Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted March 5, 2011 I have a 42" blower, but it looks like it is more or less the same as yours. I had to replace my chain last week. I got #40 chain from Tractor Supply, about $14 for a 10' length, and it comes with a master link. TT has a chain routing picture here: http://www.wheelhorseforum.com/index.php?...=25197&hl=chain Share this post Link to post Share on other sites
squonk 44,876 #3 Posted March 6, 2011 I guess mine is 42" too if you add in the water wings. the number on the blower is 96-429T01 20224 What do you use to cut the chain? Share this post Link to post Share on other sites
Kelly 1,035 #4 Posted March 6, 2011 You can use a punch to drive the pins out, set over a small socket to support the link, they make a small press, used to push the pins out, sometimes you have to grind the heads off the pins on larger chain. Share this post Link to post Share on other sites
WH854 45 #5 Posted March 6, 2011 Mike your Model# should read(96-42ST01) It is a1979 Model, put your model # in here it will give you a break down of your blower. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Chas Share this post Link to post Share on other sites
squonk 44,876 #6 Posted March 6, 2011 Mike your Model# should read(96-42ST01) It is a1979 Model, put your model # in here it will give you a break down of your blower. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Chas Thanks Chas. Is there a way to adjust the chain tension? :thumbs: Share this post Link to post Share on other sites
WH854 45 #7 Posted March 6, 2011 Mike I went out and measured the old chain that was on my blower it is 50 3/4 inch without the master link. You can adjust the chain with the adjusting sprocket(it has a sloted hole) Chas Share this post Link to post Share on other sites
