B-8074 20 #1 Posted March 3, 2011 Ok, I have a slot hitch and was thinking that I may need to get a back blade. (see moving some dirt) in the wheel horse section. I see Brinley has a 38" box scraper/back blade and a 42" back blade. However they are for a sleeve hitch. What good is a slot hitch? I never see any attachments the use it. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted March 3, 2011 The slot hitch was and there were several attachments that used it. This is what you'll need to convert sleeve (clevis) hitch attachments for use with the slot hitch: http://www.wheelhorseforum.com/index.php?...t=0entry44295 Share this post Link to post Share on other sites
B-8074 20 #3 Posted March 3, 2011 Thanks TT, I'll either make one or try to find one. After some research I found that there is a 2nd rock shaft that can go in the back. Is it necessary? I have hydro lift. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted March 3, 2011 No..... it's not really necessary. You would just have to set it up like a 1975 & older model - with the cable running from the lift shaft arm directly to the hitch. Share this post Link to post Share on other sites
WheelHorse_of_course 100 #5 Posted March 3, 2011 Thanks TT, I'll either make one or try to find one. After some research I found that there is a 2nd rock shaft that can go in the back. Is it necessary? I have hydro lift. Brinly sold these adaptors at one time and they do show up on ebay from time to time. The brinly ones are white. :thumbs: Share this post Link to post Share on other sites
