Countdown To Christmas!
repairman
1973 wheelhorse (no name project)
repairman
what I started with.
moved hood forward 3.5" to accommodate large engine :thumbs:
changed wheels to the 23" :thumbs:
have the preliminary work done to the 14 hp Magnum Engine changed oil pan from a Magnum to a 14hp K-series so the mounting bolts would be right for WH Frame :thumbs:
will continue to add pics threw out restore project will also try to add resolved issues I have ran into threw out process so others will no what will work for there projects :thumbs:
VinsRJ
Another Hot Rod....... Just the way I like them :thumbs:
sorekiwi
That'll be a good tractor with the 14hp in there.
Are you sure you need to do the hood mod? I have a B80 4 speed ("medium" frame) and the K341 bolted straight into it.
repairman
The Magnum Has a large air filter, and cooling shroud is larger and more square, Hood
wont come close to shutting with motor bolted in original mounting holes I want it to be
as close to right as possible to avoid parts waist :thumbs:
repairman
I got most of the hood work done today
this was a wrecked hood used 4.5" of the rear
this long cut down the side of the Hood was made in error so I fixed it :thumbs:
bolted motor back on
installed mule drive just so I could check the look and hood operation :thumbs:
I also put the 8" wheels on the front and a new seat today will have more pics soon
:thumbs:
repairman
I finished all Mechanical and Welding Work today took it for a test drive the 14hp Magnum is a great running Engine everything worked out well. When the weather gets warmer I will Strip and sand all of it and paint along with new decals.I am not sure what to call this Horse it was a 1973 8hp 4 speed (no name) so I am looking for good Suggestions as what to name it now in regards to decals?
:thumbs:
can whlvr
nice work,hood looks great
Horse'n Around
That came out really good, you did a nice job on it.
John
Irv
How about calling it an "EH-14 Special". (extended hood)
repairman
I like EH 14 that is good :thumbs:
dgoyette
Nice work...I think it came out looking great! I like the EH-14 as well.
frankiefiredog
Looks really nice. Great job on those welds!!! :thumbs:
I like the EH-14 as well. Goes with the flow!
Dave
Lagrange, Ohio
Duff
EH-14 sounds really good. Nice project you've got there!
Duff :thumbs: :thumbs:
repairman
Made a Headlight Lens Today not great but it will work until I find an original replacement for it :thumbs:
I also put a 48" mower deck under this machine I built this tractor for the sole purpose
using this 48" Mower and a 60" Swisher pull behind in Tandem this should give roughly
108" of mowing I hope to mow 3.5 acres in about 45 min :thumbs:
I need help with a belt size for this machine my first thought is a 42" deck would have the right length of belt but I don't know what that is need some place to start :thumbs:
DSC01112.jpg :thumbs:
jdpuller
looks good nice work. :thumbs:
Toejam
3.5 acres in 45 minutes!! :thumbs: Neeed pictures of everything hooked up!
repairman
OK so I figured out the correct size belt to run the mower 97"
I then put the finishing touches to the headlight lens.
Then I got the 60" Swisher out to charge battery and prep for mowing and started to mock up how I will make a tong for this to pull behind the horse.
so I plan to make an L shaped bracket that will pivot on the swisher side 2 Gussets at
the elbow then a Ball Receiver at the tractor hitch this should allow full motion needed to mow hills. :thumbs:
noncritical
:thumbs: Nice job i have the same tractor but no mods
dclarke
Very nice work you've done, looks good. :thumbs:
repairman
Made some more upgrades to the EH-14 Special
Cleaned and painted the wheels.
Also installed Agricultural tires to the rear
And installed an 8 speed trans out of a 1142 work horse.
Lot of work but well worth it...... :thumbs:
corn53
:thumbs: Very nice work!!! Looks sweet!!!
