mrc 955 #1 Posted February 25, 2011 hello everyone, i recently got a wh with a transplanted 20 hp onan engine in it. i was using it for snow clean up when the tractor no longer moved. i found the drive belt had slipped off the engine pulley and was laying against the engine block. i used a pry bar and managed to get it onto the pulley. i noticed on my 416-8 that there are 2 belt guides. the upper belt guide on the 416 is at the 11 o'clock position and the lower belt guide is at about the 5 o'clock postion. how many belt guides should be on this onan powered rig??? and where should they be??? thank you. mike in mass. Share this post Link to post Share on other sites
wizard 0 #2 Posted February 26, 2011 Mike the 20 onans came with and without depending on the tranny. There should be 2 belt guides on it one at 11 and the other at 7. The one at 7 comes up from the motor plate and the one at 11 comes down from the pto engine mount . Share this post Link to post Share on other sites
mrc 955 #3 Posted February 27, 2011 thank you wizard. the tractor has an 8 speed tranny. now i'll have to find another belt guide. mike in mass. Share this post Link to post Share on other sites
