Countdown To Christmas!
rydogg
My new grader machine
rydogg
Just picked up this 604 with a home made grader that looks like it will do a nice job of keeping the driveway level I realized during our first winter melt that I am gonna need some more gravel poured in the spring. The grader is well built I may drill a couple more holes so I can angle it also it has a very low hour short block replacement tecumseh how do you tell what the hp is without taking them apart?
n1defan
That a nice lookin machine. :thumbs:
Eriks Red horse herd
Nice!! straight looking old machine. Gaderblade isn't bad looking for a homade seen worse looking atempts . Should be a good work horse. :thumbs:
AMC RULES
Looks like a hard worker. You'll have to share some picts or short video of it redoing the drive. :thumbs:
stevasaurus
Very nice horse and blade. :thumbs: That Techy looks to be a 6 or 7 hp...leaning toward 7 hp. :thumbs:
VinsRJ
Nothing better than duals :thumbs:
Looks like it will get the job done.
Ken B
Nice score. Side cover says 603?
Kelly
Not a bad looking tractor, is there a metal tag on the blower housing? if so it will have numbers stamped in it, like H60 or H70 if it's a iron block not alum. it will have HH60 or HH70 the extra H stands for heavy duty, one H mean horizontal shaft.
And the belt guard is a transplant, it's for sure not a 603.
tommy3horse
Ryan;
Nice snag on the tractor! I really like the blade, looks H.D.
Good luck with the driveway, :thumbs:
Tom
:thumbs:
squonk
I just picked up a mid grader made by somebody other than :thumbs: Heavy sun of a gun. Painted orange and has the 3 holes to put the pin in to angle it. Started drawing up a mount tonight. Going to make so it will work on my 704 and C- 160
rydogg
Kelly, according to the previous owner there is no tag on the blower housing since this is a short block replacement it has a metal tag on the motor block that says SBH (short block horizontal) and has some other numbers. I drained the gas and got some new stuff in it pulled a couple times adjusted the carb and pulled a couple more and it fired up...I only ran it long enough to get the oil mixed up and hot so I could do an oil change but after I get that and the gear case oil changed it should be ready to go.
Horse'n Around
Thats a good looking tractor. With the primer on it and all it looks like someone was starting to fix it up.I like the grader blade and the dual wheel setup. Nice score :thumbs:
John
jdpuller
looks good
HorseFixer
Nice Machine! :thumbs:
HORSEPOWER79
Cool lookn horse man...i just got a mid mount blade myself
and used it the second day i had it on my buddys 2 driveways after i hauled him some rock and it is one of the best things I've got for my horse :thumbs: :thumbs:
