Countdown To Christmas!
B-8074
Hydro lift
B-8074
I was just out in the garage to grab some masking tape for my sons pinewood derby car. I noticed that I forgot to let the plow blade down when I parked the tractor. However it has bled off and is almost touching the floor. Is it normal for them to bleed off? It was parked Tuesday evening.
buckeye
If it took a couple of days, I wouldnt worry about it. Mine will bleed off after a couple days too. :thumbs:
Indy w h
Maybe you should look into some new seals??
Indy
B-8074
Thanks, I feel a little better now. I was planning on going over the whole hydro system anyhow. Just wanted to make sure I could make it till the weather breaks. :thumbs:
Kelly
I have some machines that will hold a blade up forever and others that drop it in hours, your probably due sometime for a set of seals.
