Philipp
I need to know some details about a Kohler
Philipp
In the tendency of refurbishing my c-161 I ran into a couple problems. (see the engine forum)
The first problem is that I don't have a brake on my pto. (Sometimes annoying with the mower deck.) But it isn't just the brake that is missing.
I think the previous owner cut off a part of the bracket holding the pto tensioner. Is this piece the same one used on hydro's with Kohler's AND Onans or is the one of an Onan bigger? I saw the bracket of a 520 on ebay a few weeks ago but it's gone. For my 161 it isn't available on partstree, neither on ebay for the moment. Maybe someone has the thingy that I need?
Secondly, just a random question. What are these two holes for?
At last I have a question about the governor-linkage.
At full throttle, the lever that is connected with the governor with a spring (the one I'm pointing) touches the main-throttle-cable-bracket.
Is this factory?
WH854
Howdy Philipp If you go here you can get some of the information you are looking for, just put your tractor model# in and hit search you will see several items just click on them up pops your search.Try it I used This model#(81-16K801)
https://homeownersolutions.toro.com/portal/...ductDetailsPage
OR you can go here and get Manuals for your engine(just enter as guest Scroll down hit K series engine,next page scroll down click on K341,next page you should see all the manuals for Kohler engines :thumbs:
http://www.kohlerplus.com/login.asp#
hope this helps you!!!
Chas
WH854
BTW your engine is K341AS-71246A :thumbs:
Chas
Philipp
Thank you Chas,
I found the specification number of the kohler with the help of your first site, thanks.
I have the manual of the engine here besides me, but they don't mention the support for the throttle cable.
regards, Philipp
Philipp
Okay, according to the drawings the clip on the engine should be 90 deg and in a horizontal position (maybe it's schematic?). But the throttle cable ends vertically here in the drawings...
I guess I'll just have to bend it straight to solve the problem.
Thank you and Best Regards,
Philipp
C-Series14
Well, I would look at my tractor but I am 600 miles away from it! :thumbs:
BUT, I do have pics on my 'puter! You are missing the part of bracket that holds the brake!
I know I don't have the two holes in the flywheel cover on mine.
Anglo Traction
Hi Phillip, it may be that the Throttle Cable Bracket that you say is fouling the Pivot Plate , may be acting as a Full Trottle Stop. I can't see a correct style Throttle Stop bracket on that Pivot point (see C series14's picy) :thumbs: .
Secondly, the PTO Brake Bracket on yours is identical to mine on a 74 C-120, so mine also has no Brake. I don't know when these PTO Brakes were introduced, but it is shown in a separate Box in the Parts Manual drawings for a 75 C-120 :thumbs: .
Should not be a problem to add one though.
Lastly , I do not know what the Bosses are for on your Blower Housing :thumbs: .
dodge78
I beleive this is what you are looking for on the brake.
dodge78
i found another pic
can whlvr
it looks as though your cable bracket is also your rev limitor,so if it seems to be running at a good speed i woulnt mess with it
tmessenger
I think I have one of those brake brakes off of my C120 parts tractor.
tm
Philipp
Okay, thanks for the pictures Mike. Like Richard says, there isn't a Throttle Stop bracket on the Pivot point. The bracket is serving as a throttle-stop. I'm going to see if I can make a new one (or buy one), but first I want to buy a tachometer, so I can adjust the max throttle.
Thank you for your responses.
ps: tm: I've sent you a pm.
