Tee 0 #1 Posted February 23, 2011 some day my k181 will run. i promise. my problem today is. on timing, there is a S and a T on the flywheel. correct me if i`m wrong please. the points should open on the S correct? but the S and T aint no where to be seen in the view port when the points open. what i have i done worng now. :thumbs: Share this post Link to post Share on other sites
tommy3horse 3 #2 Posted February 23, 2011 Hello Tee; Have you rebuilt it? Tom :thumbs: Share this post Link to post Share on other sites
rmaynard 16,694 #3 Posted February 23, 2011 First, set the points to an initial gap of .020. If you did a rebuild, and if you have the crankshaft and camshaft lined up properly, the S mark should line up with the mark on the bearing plate just as the points begin to open. Once the points are completely open, the S mark has already passed. The best way to determine the correct point at which the points break is with a multimeter. Share this post Link to post Share on other sites
Tee 0 #4 Posted February 23, 2011 First, set the points to an initial gap of .020. If you did a rebuild, and if you have the crankshaft and camshaft lined up properly, the S mark should line up with the mark on the bearing plate just as the points begin to open. Once the points are completely open, the S mark has already passed. The best way to determine the correct point at which the points break is with a multimeter. yes i rebuilt it and double and triple checked everything. xcept. the machine shop put the cam in looks like a no brainer to me. does the crank and timing gear go dot to dot? i got that part right, still thinkin somethin is whacked in cam. the S does not line up with open points, heck i cant even see it. thanks Share this post Link to post Share on other sites
can whlvr 994 #5 Posted February 23, 2011 i just finished a k241 (10hp)and mine had a dot on the cam and a slot on the crank,the slot is formed right in the ckank,if yours had a dot then it should be dot to dot,as long as u didnt use the secondary cam mark Share this post Link to post Share on other sites
Tee 0 #6 Posted February 23, 2011 i just finished a k241 (10hp)and mine had a dot on the cam and a slot on the crank,the slot is formed right in the ckank,if yours had a dot then it should be dot to dot,as long as u didnt use the secondary cam mark Secondary cam mark? thought there was just one or least that what is saw. thanks Share this post Link to post Share on other sites
rmaynard 16,694 #7 Posted February 23, 2011 On the K241 crankshaft there are two marks. The one closest to the gear is the one that gets aligned with the cam gear dot. The other is for balancing gear timing if you have them. Share this post Link to post Share on other sites
MikesRJ 558 #8 Posted February 23, 2011 This tutorial by T-Mo may help you. You also may want to remove the flywheel again, and paint the letters and lines with white paint do that you can see them through the viewing port when reassembled. http://www.mywheelhorse.com/graphics/file/...ngineTiming.pdf Share this post Link to post Share on other sites
Tee 0 #9 Posted February 23, 2011 This tutorial by T-Mo may help you. You also may want to remove the flywheel again, and paint the letters and lines with white paint do that you can see them through the viewing port when reassembled. http://www.mywheelhorse.com/graphics/file/...ngineTiming.pdf I painted the S and T, did the static timing test. problem is, there is no S and T showing in the viewing hole, when points are open. The points open some other time. goofy as it sounds. thanks Share this post Link to post Share on other sites
Kelly 1,035 #10 Posted February 23, 2011 sounds like the cam and crank are not timed correctly, pull the pan off and check the timing marks. Share this post Link to post Share on other sites
Tee 0 #11 Posted February 28, 2011 sounds like the cam and crank are not timed correctly, pull the pan off and check the timing marks. ok i pulled the engine apart. 3rd times a charm, now, when i put the cam shaft dot to line up up with the crank dot. the cam lobe is down points closed, when i flip it 180 the cam lobe is up and the dot is now about the 2 o clock position. only 2 ways a i can set this. thanks Share this post Link to post Share on other sites
mattd860 162 #12 Posted February 28, 2011 Like rmaynard said - The points only BEGIN to open when the 'S' mark is viewable in the window. The S timing mark has come and gone long before the points are fully open. When you get the motor back together, align the timing mark with the S and continue to turn the motor in the direction of normal operation. After the S mark has passed the timing mark, then the points should slowly open. When the points have opened all the way, then you begin to set the point gap. Like I said, when the points have opened all the way, the S timing mark will be long gone. Share this post Link to post Share on other sites
dgjks6 8 #13 Posted February 28, 2011 man I feel your pain. Put them dot to dot. and put the pan back on. I just did this and had a hard time but figured it out and I can try to walk you through it step by step. Have you found the "s" on the flywheel? Share this post Link to post Share on other sites
Tee 0 #14 Posted February 28, 2011 Like rmaynard said - The points only BEGIN to open when the 'S' mark is viewable in the window. The S timing mark has come and gone long before the points are fully open. When you get the motor back together, align the timing mark with the S and continue to turn the motor in the direction of normal operation. After the S mark has passed the timing mark, then the points should slowly open. When the points have opened all the way, then you begin to set the point gap. Like I said, when the points have opened all the way, the S timing mark will be long gone. yes i found the S in big white now. i was under impression the S was where the points were set. my bad, now its gettin clear. thanks Share this post Link to post Share on other sites
Tee 0 #15 Posted February 28, 2011 man I feel your pain. Put them dot to dot. and put the pan back on. I just did this and had a hard time but figured it out and I can try to walk you through it step by step. Have you found the "s" on the flywheel? ok, if i put it dot to dot. at the cam and crank. the lobe of the cam is now down. is this what i want? i may need to do a better visual of the crank. there is a mark on the counter weight, is that where the mark is our is it close to the pto journal>? thanks fellers i really appreciate your time. :thumbs: Share this post Link to post Share on other sites
dgjks6 8 #16 Posted February 28, 2011 I don't get pictures on my computer here at work, but read this thread. I started it and TT put some good pics up of the marks. http://www.wheelhorseforum.com/index.php?showtopic=23532 Share this post Link to post Share on other sites
Tee 0 #17 Posted March 1, 2011 I aint never been happier than when my grankids were born. i found the timin mark on the crank. (i was lookin at a lil casting flaw all along hahahaha) its right down on the shaft on the counter balance where the machining stop. ii dot to dot the timing . now i`m gettin somewhere. thanks fellers for all the help. :thumbs: Share this post Link to post Share on other sites
