earlleecliffton 38 #1 Posted February 20, 2011 i have a 1277 and just got the engine referbished. its running great but for the life of me i cant figure out how the throttle and choke cables were routed. anyone got pics to help me. it the only thing i didnt get pics of. thanx. Share this post Link to post Share on other sites
earlleecliffton 38 #2 Posted February 21, 2011 pretty please? someone Share this post Link to post Share on other sites
earlleecliffton 38 #3 Posted February 23, 2011 bump Share this post Link to post Share on other sites
Kelly 1,035 #4 Posted February 24, 2011 I don't have pictures right now, but let me see if I can confuse you and try to tell you, the throttle cable goes just above the belt guard (some tractors have a flat bracket the cable gets clamped to and is held in place by the top belt guard bolt) and under the exh. turns to face the fuel pump, and gets clamped to the stud that holds the breather cover on, then the wire inside hooks to the piviot on the blower housing. choke goes down under the blower housing and up to a bracket sticking off one of the blower bolts, that is where it gets clamped, then the wire hooks to the carb/choke lever. Hope this helps. Share this post Link to post Share on other sites
earlleecliffton 38 #5 Posted February 25, 2011 thank you very much. i think im missing the pivot bellcrank Share this post Link to post Share on other sites
earlleecliffton 38 #6 Posted February 25, 2011 my cable was hooked to this somehow but i need the bellcrank Share this post Link to post Share on other sites
daemon2525 5 #7 Posted February 26, 2011 Maybe this will help? Some of the ones that I have seen have a straight bar on the blower shroud and others have have an "L" shape (bellcrank). Share this post Link to post Share on other sites
earlleecliffton 38 #8 Posted February 27, 2011 thanx larry. kelly, how much would it cost for u too mail me thelinkage rod , thelong bolt thing that goes in breather cover, and bolt and linkage on blower housing?? if u have it that is. ??? Share this post Link to post Share on other sites
daemon2525 5 #9 Posted March 4, 2011 Check your PM.I have some of those parts Share this post Link to post Share on other sites
