jdog_kustoms 82 #1 Posted February 20, 2011 i was just wondering if these cast iron wheel weights on a gt 14 i just picked up origonal or something home made Share this post Link to post Share on other sites
64s 83 #2 Posted February 20, 2011 I'm not an expert on these but I would bet they're original - and should be mounted on the inside of the wheel. Share this post Link to post Share on other sites
Brrly1 1,146 #3 Posted February 20, 2011 My guess is they are most definitely original. They will also fit a 953,1054 and of course a GT14. Yes they are made to bolt in from the inside. :thumbs: Share this post Link to post Share on other sites
partsman6656 0 #4 Posted February 20, 2011 Yes, they are original weights. They mount to the inside of the wheel HUB and not the wheel. Mounted correctly, you have 4 lug nuts to remove and the wheel and tire comes off while the weight stays attatched to the hub. If you look on Toro's MPV site, enter WW-93 as the Model and you can see a sectional view of the proper assembly. Good luck! Share this post Link to post Share on other sites
wh1257 226 #5 Posted February 20, 2011 it looks wow this is very spacial I think Share this post Link to post Share on other sites
oldandred 16 #6 Posted February 21, 2011 yep there the real thing I have a set like Burrly1 said can be mounted out or in side Share this post Link to post Share on other sites
