skrusins
Seat question on 95 314H
skrusins
Is there a simple mod to get the seat back
further? I adjusted it back as far as I could
even turned the springs around to get another
inch. I know if I lost about 4 inches off my
stomach that would help. I thought maybe
someone else has this problem. Even the brake
pedal is too close. Thanks
WH854
I made the slots in the seat plate a little bit longer(the plate the springs bolt to if you know what I mean)Worked for me :thumbs:
Chas :thumbs:
skrusins
First thanks for your help. I'm glad to see someone had this issue.
I look at my base and the slots are almost to the bumpers, in which
if I cut the bumpers off it may give me a 1/2 in. Is that what you did?
thanks again for your help.
WH854
The bumpers are in a different hole,outside of the slotted holes!! I took them(bumpers I mean) off and made the slots longer.Then I put bumpers on the bolts that hold the spring on the plate. That way you don't rub the paint of your fender pan. I think the P/N for rubber cups are Toro P/N 108889 bolt P/N 908020 hope I made myself clear!!!
Chas
skrusins
Got it! Thanks for your help
