Pollack Pete 2,273 #1 Posted February 17, 2011 I'm working on my recently acquired Wheel Horse 856 with a Kohler K-181S engine..I usually start repairs with the fuel system.I already rebuilt the carter carb.Today I took off the fuel pump.At first,I thought the pump arm was missing,then I realized it's a vacuum operated pump.Any rebuild kits available for these pumps?What size Kohler started using a mechanical pump?Thanks for any and all info. Share this post Link to post Share on other sites
DMK855 15 #2 Posted February 17, 2011 Pete, I am working on a K181 fuel pump as we speak. I have a kit coming for the vac. pump this week from a company in Ma. If it works, I will let you know. The kits are no longer available from Kohler. If your motor has the eccentric on the cam for the pump, you can use a mechanical pump. Replacement mechanical pumps can be had for around $45.00 give or take!! The kit (if it works) was 29.00 to my door!! Best of luck!! Share this post Link to post Share on other sites
qd-16 15 #3 Posted February 17, 2011 Check with redsquare member "buckrancher" , he sells a rebuild kit for your vacuum fuel pump, I think its around $5 . I got one from him and it worked great. :thumbs: Share this post Link to post Share on other sites
keg 0 #4 Posted March 9, 2011 my fuel pump is geting a little weak om my magnum 12 horse. so i installed a boat primer bulb that u hand squeze i only have to (prime) the pump 1 time before start up then the pump picks up and runs fine i dnt know how long shel last but just an option if any 1 is having the same prob. and it may work for u. unless its totally gone out. p.s also if any 1 knows were i can get the pump for that motor reasanable it would b apreciated. :thumbs: Share this post Link to post Share on other sites
KB9LOR 4 #5 Posted March 9, 2011 my fuel pump is geting a little weak om my magnum 12 horse. so i installed a boat primer bulb that u hand squeze i only have to (prime) the pump 1 time before start up then the pump picks up and runs fine i dnt know how long shel last but just an option if any 1 is having the same prob. and it may work for u. unless its totally gone out. p.s also if any 1 knows were i can get the pump for that motor reasanable it would b apreciated. Is it a vacuum pump or a mechanical? or do you have a part #? Share this post Link to post Share on other sites
Indy w h 5 #6 Posted March 9, 2011 There's a member here that sells fuel pump kits PM Mike-Casella Indy Share this post Link to post Share on other sites
keg 0 #7 Posted March 10, 2011 it is a mechanical pump i dnt have the part number at the time Share this post Link to post Share on other sites
KB9LOR 4 #8 Posted March 10, 2011 it is a mechanical pump i dnt have the part number at the time Here are the part #'s for your fuel pump: Kohler Numbers 47-559-03s 47-559-04s 47-559-11s they fit M8, 10, 12 , 14, 16 & K241, 301, 321, 341 & 361 I can get it "brand new" for $37.50 shipped to your door. Share this post Link to post Share on other sites
MikesRJ 558 #9 Posted March 11, 2011 I can get it "brand new" for $37.50 shipped to your door. Metal or plastic? Share this post Link to post Share on other sites
daemon2525 5 #10 Posted March 11, 2011 it is a mechanical pump Share this post Link to post Share on other sites
KB9LOR 4 #11 Posted March 11, 2011 I can get it "brand new" for $37.50 shipped to your door. Metal or plastic? These are the metal ones. Share this post Link to post Share on other sites
KB9LOR 4 #12 Posted March 11, 2011 it is a mechanical pump Share this post Link to post Share on other sites
KB9LOR 4 #13 Posted March 11, 2011 I cross referenced your number, and it is showing not found, you may have a bad part number.. Share this post Link to post Share on other sites
daemon2525 5 #14 Posted March 11, 2011 I guess that I am lost then. The original poster wanted a fuel pump for a K181 as do I. I think that the part number is 41-559-05 I am ready to buy this part. if it's not the right part number then it would be great to know that. http://cgi.ebay.com/NEW-Kohler-Fuel-Pump-K...=item415329b72a Share this post Link to post Share on other sites
KB9LOR 4 #15 Posted March 11, 2011 I guess that I am lost then. The original poster wanted a fuel pump for a K181 as do I. I think that the part number is 41-559-05 I am ready to buy this part. if it's not the right part number then it would be great to know that. http://cgi.ebay.com/NEW-Kohler-Fuel-Pump-K...=item415329b72a Per what they have posted those number are showing up in my catalog as being the pumps for a k241, 301, 321, and 341, not for a k181, but give them a call, and see what they tell you, it isn't going to hurt to ask. Share this post Link to post Share on other sites
DMK855 15 #16 Posted March 12, 2011 There's a member here that sells fuel pump kits PM Mike-Casella Indy Here is a thread of mine with pictures of the rebuild kit from Mike Casella. I was very happy with the kit. http://www.wheelhorseforum.com/index.php?showtopic=25706 Share this post Link to post Share on other sites
