rocking 416 1 #1 Posted May 13, 2008 how do you check the hydrolic fluid for the hydro lift on a 416 , is it same as checkign trans fluid ? Share this post Link to post Share on other sites
nylyon-(Admin) 8,611 #2 Posted May 13, 2008 There is only one hydraulic system on the 416-H which powers the trans and the lift. You check it with the dipstick under the seat. Share this post Link to post Share on other sites
rocking 416 1 #3 Posted May 13, 2008 thats what i figured my pump seems to growl alot tho when i lift it the flid is clean i use 10w40 like deelership said Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted May 13, 2008 Do you have the correct filter? (and have you changed it too?) :whistle: Share this post Link to post Share on other sites
rocking 416 1 #5 Posted May 13, 2008 as far as i know its the rite one it was deelership serviced an it has a horse head on the filter an its black, i was told it was serviced every year Share this post Link to post Share on other sites
illinilefttackle 399 #6 Posted May 13, 2008 :WRS: Rocking... I am not a WH expert,nor did I play one on TV-but I am a WH hydro owner. When I first got mine-the Hydro noise bothered me-I didn't know if it was supposed to do that. It would "Howl" a little all the time,but much more when really working. Then I remembered hearing a Zero Turn Mower in operation cutting grass at a business-it had the same "Howl" when working. Personally I wouldn't worry unless it stops pulling or lifting well.-AL :whistle: Share this post Link to post Share on other sites
rocking 416 1 #7 Posted May 13, 2008 LOL ..i head ya al thanks for the info i heard em growl too an the fluid is clean so i trust it Share this post Link to post Share on other sites
