sgtsampay 117 #1 Posted February 4, 2011 Hello all. I have been doing some thinking lately. The problem: As you most you guys know, I have a Workhorse GT1600 that I got from a fellow member and I refurbshed the tranny and gave it some much needed TLC on the chassis. I also rebuilt the PTO bell and got a new clutch plate. Then i put my cab on it. I haven't done much work with the motor, but an oil change, replaced the gas lines, plugs and cleaned the jets and away I went. The machine gets the job done and all but uses lots of fuel (About 1-1/2 -2 tanks per storm. thats doing 7-8 driveways) and bogs down pretty easily. Also, I have notiecd that I get about 55psi in each cold jug when I do a compression test, so I think its needs a rebuild. The solution: I really don't want ot rebuild the engine and spend several hundred dollars on a 16Hp when for not much more I could get a V-twin that would use less gas, be more powerfull and for the first time ever, be new or semi new. The Question: Now should I go desiel or gas? IS there any place where I could get a good deal on a motor? Does anyone here have a V-twin that they want to sale? Is a chinese clone desiel bad? If you gusy have any other things i should think about or whatever, feel free to post. Thanks guys for all for the help and I can't wait till the get a new motor, as this tractor of mine, i really like. Its a huge step up from the little 211-5 that I was using for about one year. :thumbs: Share this post Link to post Share on other sites
nylyon-(Admin) 8,563 #2 Posted February 4, 2011 I don't know if the little diesel's are different but with my F250, the diesel doesn't like cold weather very much (and no Ford bashing I have a very good 6.0). If you're using the machine in the winter, you may want to stick with a gas motor. Share this post Link to post Share on other sites
sgtsampay 117 #3 Posted February 4, 2011 Hmmm. Never though about that.... Share this post Link to post Share on other sites
massey 119 #4 Posted February 4, 2011 I'm also considering a diesel for the next project. A dipstick heater to keep the oil warmed for the winter use would probably help for starting. Any thoughts? Share this post Link to post Share on other sites
Jim_M 179 #5 Posted February 4, 2011 I have the big clone diesel (13 hp, I think) on a 520-H. It has a glow plug for cold weather starting. It's never let me down but it really stinks up the garage on a cold day. A Briggs Vanguard V twin may be the answer for you, lots of power and good fuel economy. Share this post Link to post Share on other sites
sgtsampay 117 #6 Posted February 4, 2011 OK, so it seems like a diesel is not the way to go for me... OK, so now how do I get Briggs Vangaurd for a decent price and 2,000 bucks? Share this post Link to post Share on other sites
Jim_M 179 #7 Posted February 4, 2011 http://smallenginewarehouse.com/product.as...520H%20tractors Share this post Link to post Share on other sites
sgtsampay 117 #8 Posted February 4, 2011 Dang, 1.3K for one of those. Wow.. I will try and look for a used one first.. I jsut don't have that kind of cash. My budget would be about 500-600 max. Share this post Link to post Share on other sites
KB9LOR 4 #9 Posted February 4, 2011 Hello all. I have been doing some thinking lately. The problem: As you most you guys know, I have a Workhorse GT1600 that I got from a fellow member and I refurbshed the tranny and gave it some much needed TLC on the chassis. I also rebuilt the PTO bell and got a new clutch plate. Then i put my cab on it. I haven't done much work with the motor, but an oil change, replaced the gas lines, plugs and cleaned the jets and away I went. The machine gets the job done and all but uses lots of fuel (About 1-1/2 -2 tanks per storm. thats doing 7-8 driveways) and bogs down pretty easily. Also, I have notiecd that I get about 55psi in each cold jug when I do a compression test, so I think its needs a rebuild. The solution: I really don't want ot rebuild the engine and spend several hundred dollars on a 16Hp when for not much more I could get a V-twin that would use less gas, be more powerfull and for the first time ever, be new or semi new. The Question: Now should I go desiel or gas? IS there any place where I could get a good deal on a motor? Does anyone here have a V-twin that they want to sale? Is a chinese clone desiel bad? If you gusy have any other things i should think about or whatever, feel free to post. Thanks guys for all for the help and I can't wait till the get a new motor, as this tractor of mine, i really like. Its a huge step up from the little 211-5 that I was using for about one year. Several hundred to rebuild? I can do better than that, I would go through and rebuild it,(Especially if I measured the Bore, Crank and Rod) and could just re-ring it and I have the very same Tractor, it is what I would do! I would go Diesel, but way more than what I want to pay for one. Share this post Link to post Share on other sites
sgtsampay 117 #10 Posted February 4, 2011 Hmm. But even if i do rebuild it, wouldn't the gas comsumption still be high? Also, I really would like something bigger than the 16Hp. Mabye I'm being to greedy? All I want it to do is be able to snowblower with a 44in 2 stage in 1 high and mow with a 42in rear in 1-2 high. Thats really all I want it to do I guess. Share this post Link to post Share on other sites
Jim_M 179 #11 Posted February 4, 2011 I'm betting if it was rebuilt and properly tuned it would use much less gas and I know it would have more than enough horsepower to do what you want to do with it. A 10 horse tractor will run a 42" deck just fine so there's no reason a 16 horse won't. Share this post Link to post Share on other sites
sgtsampay 117 #12 Posted February 5, 2011 Hmm. Well, I guess I may have to rebuild the thing. I do have aonther briggs 16Hp twin that I could get running if needed also. Hmm. Share this post Link to post Share on other sites
sgtsampay 117 #13 Posted February 5, 2011 Also, would vavle job give it some more power/compression and better fuel ecomomy? Share this post Link to post Share on other sites
Audioshot 2 #14 Posted February 5, 2011 Wow! How big of a deal is it to get that Vangaurd into my 1990 310-8? Would the PTO still bolt up? Share this post Link to post Share on other sites
mavfreak 11 #15 Posted February 5, 2011 that's something else to consider in an engine swap. How much do you have to do to make it work, such as the PTO or the output shaft size. Also the electronics going to be the same or are you going to have to rewire it. I would say a rebuild would probably be the cheapest rout to go as long as all the expensive parts are usable or serviceable. Share this post Link to post Share on other sites
baerpath 517 #16 Posted February 5, 2011 I googled a 16hp briggs and it came up that it does have an ACR so don't go by the comp test do a leak down after checking/adjusting the valves. Heck snowblowing sucks the gas no matter what engine you have Duane Share this post Link to post Share on other sites
KB9LOR 4 #17 Posted February 5, 2011 Hmm. But even if i do rebuild it, wouldn't the gas comsumption still be high? Also, I really would like something bigger than the 16Hp. Mabye I'm being to greedy? All I want it to do is be able to snowblower with a 44in 2 stage in 1 high and mow with a 42in rear in 1-2 high. Thats really all I want it to do I guess. I believe it would do better, ever put gas in a 16 or 20 Twin Onan with 2 stage? It cannot be any worse than one of those, maybe one of the other 'D" guys can chime in here, I have one of those, but no blower, and even pushing dirt it is a hog!, But I like it anyways..lol, but seriously, rebuilt, tuned up, that Briggs will hum! And you are going to have MORE trouble lifting that blower than that Briggs running that. Share this post Link to post Share on other sites
can whlvr 994 #18 Posted February 5, 2011 i too was wondering about the compresion test,,i read on herea trick,(it was tt that suggested it,u hook up another wheelhorse to the pto to pto on the gt vangaurd,u might have to do a figure 8 then u can check the cimpression,it will be turning at near full rpm,s,and if u rebuild the briggs she will be good for a good long time Share this post Link to post Share on other sites
sgtsampay 117 #19 Posted February 5, 2011 Hmm. Well, its seems like for now I will check the valves next week and see if they are in spec. I will then use it and go from there. I will still keep an eye out for a Vtwin but I may rebuild the engine during the summer. I really don;t know, as I have to see what my bugdet is at the time. So is sucking down 5-6gallons of gas for 11 drives decent? Share this post Link to post Share on other sites
Guest #20 Posted February 5, 2011 Dang, 1.3K for one of those. Wow.. I will try and look for a used one first.. Share this post Link to post Share on other sites
wh500special 2,359 #21 Posted February 5, 2011 I know nothing of their durability, reliability, or quality but you could get the best ( or worst) of all worlds and try a Chinese v-twin diesel. A1biofuels Not cheap...but it's not my money The Briggs twin 16's are pretty nice engines. Rebuilt, it should easily be able to run with any other 16. The 18's are essentially the same, so if looking for a used one don't be shy about widening your search. Good luck! Steve Share this post Link to post Share on other sites
Guest #22 Posted February 5, 2011 Looks like the hongda can be had for around $870- not sure if I'd chance it at that price unless it was down to something like $600, and I'd seen a few people use them. Share this post Link to post Share on other sites
sgtsampay 117 #23 Posted February 5, 2011 Well I did some research on the clone and think it may be a possability. Here are its specs: Model: 2V77F(CE/EC, EPA)(20PS) Engine type: V-TWIN-cylinder 4-stroke with forced air-cooled OHV Bore*stroke: 77mm*66mm/77mm*72mm Displacement: 614ml/670ml Compression ratio: 8.3:1 Max power output: 12.5kw/3600rpm Recommend power using: 12kw/3600rpm Max torque: 40N.m/2500rpm or 30ftlbs Ignition system: Non-contact transistorized ignition(TCI) Start model: electric Air cleaner: Semi-dry oil bath type Fuel tank capacity: Fuel consumption: 374g/kw.h Engine oil capacity: 1.4L Dimension(L*W*H mm): 455*396*447 Dry weight: 42kg Carton dimension(L*W*H mm): 660*550*640 QTY/20GP: 95 QTY/40GP: 203 QTY/40HQ: 271 Now, I also noticed a few dealers in my state who can sale these engine, so I want to know how much it will cost for one of these. I also need to know the output shaft of the thing. I know none likes the clone but honstly they are here to stay and since history likes to repeat itself I bet in a few decades they will be pretty good. Also, I read the warrenty and they is a 3 year warrernty that comes with this thing. Share this post Link to post Share on other sites
B-8074 20 #24 Posted February 5, 2011 Look at it this way. You can always increase the HP during a rebuild. Check around and see what kind of HP you could get. Share this post Link to post Share on other sites
pfrederi 19,278 #25 Posted February 5, 2011 Hmm. Well, its seems like for now I will check the valves next week and see if they are in spec. I will then use it and go from there. I will still keep an eye out for a Vtwin but I may rebuild the engine during the summer. I really don;t know, as I have to see what my bugdet is at the time. So is sucking down 5-6gallons of gas for 11 drives decent? How long (time wise) are you blowing??? The Kohler twin on my 418 probably burns 1.5-2gals per hour blowing. Wide open throttle and the governor pulling hard is bound to eat up fuel. The KT 17 on my plow girl doesn't exactly win the Shell Oil fuel economy challenge. Share this post Link to post Share on other sites
