repairman 7 #1 Posted February 3, 2011 Does anyone have a manual that covers 14 hp magnum engines? I have the opportunity to purchase one of these engines, would like to see what the differences are in this engine versus the K-series. in regards to wiring overall dimensions throttle and choke cable routing looking at this engine as a replacement for a K-Series 8 hp. :banghead: Share this post Link to post Share on other sites
rmaynard 16,694 #2 Posted February 3, 2011 You can download a .pdf copy at Kohler's website: http://www.kohlerplus.com/login.asp Enter as a guest. Then select Magnum Engines and your M14 manuals will be there. Note: You have to use Internet Explorer to view the site. Other browsers don't work. or you can go to MyWheelHorse.com and check the manual archive for Kohler "M" series. Share this post Link to post Share on other sites
pfrederi 19,272 #3 Posted February 4, 2011 I put a Magnum 12 in a C-81 to replace the K series. Converted it to the special oil pan to fit the shaker mounting on the C-81. Some twiddling was required to route the throttle cable and get the aircleaner and shrouding to fit, nothing insurmountable One unresolved issue was the choke linkage. It works backwards. e.g. move lever up choke off down choke on. Not a big problem, I call it my anti-theft device. Share this post Link to post Share on other sites
