Countdown To Christmas!
312horse
major fuel leak
312horse
The fuel valve on my 312-8 fell out of the tank , it appears to have somehow destroyed the rubber bushing ( part number 104047 ) maybe someone has another idea on hoe to hook to the tank ? it looks like 3/8 pipe would almost tighten in there maybe ? otherwise does someone have that rubber bushing for sale ? :banghead:
TT
Check your local small engine shops and lawn & garden equipment dealers.
Many brands used the same grommet:
CUB CADET 735-0149
CUB CADET 935-0149
EXMARK 1-513645
MTD 735-0149
MTD 935-0149
NOMA 42690
SCAG 482571
SCAG 48309
SIMPLICITY 1654930
SNAPPER 1-2337
SNAPPER 7012337
STENS 125-336
TECUMSEH 33679
TORO 104047
TORO 46-6560
TROY BILT 1738433
TROY BILT 935-0149
312horse
i thank you , does that grommet just push back in there, and you then push the valve in it ? nothing on the inside of tank to tighten ?
6wheeler
It does on mine. Terry is right, I had no problems finding one. I think it was only about $6.00 too.
312horse
Thanks fellas , i,ll check around tommorrow
Duff
Just to give you a heads up - when you push in the grommet (bushing), it fits VERY tight. Then when you go to push the shut-off valve through the bushing, that's even tighter. I used some silicone grease on both to get them to slip in and they seem to be holding very well. The tight fit is worth it, though - once in place it won't leak or come loose for many years!
~Duff :banghead:
312horse
i thank you for that info , hopefully i can find one tommorrow
312horse
Duff , did you get your winch headed your way?
KC9KAS
I thought my leaking problem was the rubber grommet, but turns out the tank had a crack (in the seam).
Tried all kinds of stuff to fix it, and ended up buying another tank.
Beware!
Sparky
Dont do what I did once. I stuck the shutoff into the rubber grommit first and then tried to shove it into the tank :banghead: .
Mike.....
312horse
Thanks Mike for that tip
Duff
Got sidetracked, but should be ordering it this week!
~Duff :banghead:
