ryan2121 1 #1 Posted January 29, 2011 Ok like the topic says I just bout some new 36 led panel headlights , that I had seen mentioned on here but when I went to install them they are so dim you can barely tell there even lit. I used a volt meter and checked the socket and I am getting 12v. The only thing I can come up with is when I pulled the engine I forget to disconnect the stator so in a bind I cut the wires, if I would have spliced these back together wrong could this affect my lights? Also this is on a 76 C-120. And the taillight is still working fine just as bright as ever. Share this post Link to post Share on other sites
just me 0 #2 Posted January 29, 2011 just a guess but maybe a week ground also did you try at halve or full throttle? Share this post Link to post Share on other sites
rmaynard 15,936 #3 Posted January 29, 2011 As to the stator question, you cannot splice it wrong, only bad. It is AC voltage. Are the lights bright if you hook them directly to the battery? Remember, LED's are polarized, (+) must got to (+) and (-) to (-). When running at full throttle, you should have +/- 14.5 volts DC at the battery. I would test them with a direct connection to a known, good source of 12 volts DC. Share this post Link to post Share on other sites
smoreau 658 #4 Posted January 29, 2011 As to the stator question, you cannot splice it wrong, only bad. It is AC voltage. Are the lights bright if you hook them directly to the battery? Remember, LED's are polarized, (+) must got to (+) and (-) to (-). When running at full throttle, you should have +/- 14.5 volts DC at the battery. I would test them with a direct connection to a known, good source of 12 volts DC. thats right leds have to be wired right for them to work. try reversing the wires at the lights. :banghead: Share this post Link to post Share on other sites
WheelHorse_of_course 99 #5 Posted January 30, 2011 thats right leds have to be wired right for them to work. try reversing the wires at the lights. :banghead: Share this post Link to post Share on other sites
ryan2121 1 #6 Posted January 31, 2011 Ok I got the lights to work I ran all the wires down and found a break in the headlight wire, Im guessing it was just making enough connection to show voltage on the meter but not enough to light up the lights. I replaced the wire and all is good now. Share this post Link to post Share on other sites
Sparky-(Admin) 22,210 #7 Posted January 31, 2011 Can we get a picture of this setup? Mike........ Share this post Link to post Share on other sites
wheelhorse656 20 #8 Posted January 31, 2011 Can we get a picture of this setup? Mike........ i agree with sparky Share this post Link to post Share on other sites
