ron2681
Front weight
ron2681
I sold my friend a 1076(which I miss very much), and he bought a plow for it, he says it works great but wishes it would steer better when pushing, any suggestions or ideas for front weight- would that help??
can whlvr
have u tried the roller chain on the front tires,works great,with some xtra weight it would work good
sorekiwi
Some guys put weights on the front wheels, or load the tires. I've never done either so I cant tell you how effective it is.
I use tri-ribs on the front of my 1276, and it was a night and day difference. The steering actually got lighter, but the tractor turns a whole lot better than it did with the slightly wider turfs.
Another thing I havent tried is the roller chain around the circumference of the front tire. There are a couple of threads on it here, and the guys that have done it swear by it.
I stopped looking for an improvement as soon as I put the tri-ribs on.
buckeye
you could sit on they hood while he plows :banghead: he could put fron wheel weights on it, if he can find them. maybe buy some ribbed tires. or go the cheapest route and do the #40 roller chain trick. I think their is a couple threads on here somewhere about using chains on the front tires.
