Countdown To Christmas!
118lfd
Made some wheel weights
118lfd
I used some lead ingots I got from my uncle. I picked up a 12" cast iron skillet from target and a propane weed torch from harbor freight.
They weigh about 80lbs each
The skillet is tapered and they fit really nice in the wheels
Work area outside Good ventilation
Completed and installed
dandan111
They look great,nice job.
danjmah
Very Nice!
wheelhorse656
sweet :thumbs: :banghead:
smoreau
:banghead: I want a set too, looks very nice :ROTF: :thumbs:
Dresden Guy
Hey, they look great! I'll take a set.....spray my red with the WH decal in the middle. :banghead:
Super job! :thumbs:
KC9KAS
Very clever, and the heat melted the snow around your work area!
Roger from southern Iowa
They look very good!!! :banghead:
118lfd
Not too hard to make guys. I have about 2 hours in them. The 12 inch cast iron skillet was 18.00 and the torch was 20.00. I used some leftover propane from the grill. The taper from the skillet made the weights center themselves in the rim.
Arndts small engine repair
Hi very nice ! :banghead:
Sparky
Lookin good :banghead: .
Mike.........
can whlvr
looks great, :banghead: and u could route wheelhorse with a template and a router with a sacrificial bit,just thinking
dgjks6
I bet if you find a skillet for 6 and 8 inch front wheels you could make some $$.
They look great. And Superman can't see through them.
massey
Nice work there.
neil
Genious :banghead::thumbs::ROTF::hide::hide:
may give that a go here in uk
118lfd
I can't take the credit, someone on here made a set using a 12 inch cake pan and routed a notch for them to fit. I just wanted to get around machining them to fit. The 6 inch skillet would work, I might try that as I have a bunch of ingots left.
The best part was trying to pick them up after I layed them down to drill the holes. I looked like a monkey trying to F*&^ a football. I ended up using a putty knife to get under them and then a long screwdriver to pry them off the floor :D Was quite funnny
Duff
The best part was trying to pick them up after I layed them down to drill the holes. I looked like a monkey trying to F*&^ a football. I ended up using a putty knife to get under them and then a long screwdriver to pry them off the floor :hide: Was quite funnny
Oh, the mental images that conjures up! :thumbs::ROTF::hide:
Duff :banghead:
Fiscalyear
:thumbs: Good idea. And in my price range. My pony slips a little in the front when angle pushing so I'm looking forward to your production of smaller weights for the front. My problem is I don't have lead. I know lead is much heavier but do you think concrete would work? :banghead:
Eddie
KC9KAS
Concrete will work, but you will need to put some type of sleeve (for the bolts) in the wet concrete before it sets up.
I wouldn't attempt to drill the concrete as it is a very small piece (with no re-inforcement) and the hammer drill will probably break it into many pieces.
just me
I'm sure there is somewhere we could get lead or aluminum(might not be as heavy but would work)
118lfd
Used some of my leftover ingots to add some more weight. 1/2 threaded rod and 2 nuts to the drawbar. Drilled 1/2 inch holes in each ingot. Without the hole each one weighs about 20lbs so 100lbs total.
COMMANDO1
YES MORE WEIGHT.
jimbotelho
what did you use for a releasing agent to remove the lead weight from the skillet :banghead: :thumbs:
stevasaurus
You do not need a releasing agent to release the lead...it will tap out when it cools.
A neat trick with lead, is to take a plumbers candle and wipe it on the lead as it cools. The wax gets in to the surface and will keep it from oxidizing...turning white...which is the hazardous stuff. It will look like new for a long time. :thumbs: You can do it later this spring by warming them up...the wax works like a cleaner and a flux for soldering.
Nice job on the weights. :banghead:
