tmix 34 #1 Posted January 23, 2011 875 is leaking ATF behind the lever forward and reverse is there a O ring that went BAD ???When I have it in Neautral its vibrates the shifter forward and she wants to run away on me I am not in the Saddle !!! These pictures the spring seems tight.The little slider bars on the sides look Bad but the piece its holding is Plastic Right GUYS. WHen I push on the brake it stays in neautral but after a while the vibration the shifter and shes out running by her self !!! WOOOOOA NELLY!!!! You can seem from the pictures I have a sheet a paper under shifter and it leaks ATF like a shive PLEASE HELP LOST in the U.P. T MIX BACK TO THE GAME GO PACK GO !! P.s there's a spring hooked to God knows what does it have a HOME it was like that when I got it !! Share this post Link to post Share on other sites
smoreau 658 #2 Posted January 23, 2011 I beleve there is a seal in the sundstrand pump were the swash plate shaft input is . on the other side there is a oring but that side should be a seal. Its been some time sence I was in mine. I dont know were to get one but I'm sure some one will step in and tell you were to get it. got to love them 875's also the plastic slide plate looks warn on the sides where the two screws with splings are. I think that is why the shifter slides forward. if you get off you should pull the parking brake under the front of the right rear fender. this disenguages the belt and also sets the parking brake inside the diff housing. good luck :ROTF: 1 Share this post Link to post Share on other sites
smoreau 658 #3 Posted January 24, 2011 here are some pics of my 875 service book I hope these will help :banghead: Share this post Link to post Share on other sites
tmix 34 #4 Posted January 24, 2011 :banghead: Nice 875 do you use It. Looks new tmix Share this post Link to post Share on other sites
smoreau 658 #5 Posted January 24, 2011 no it was my grand fathers and he bought it in 65 new and its been passed down and now i want to restore it for my father. I will try and post a link to my first restore. my first resto its 5 pages back in this catigory on jan 2 Share this post Link to post Share on other sites
boatman 3 #6 Posted January 24, 2011 :banghead: Hi, There is a o ring seal behind the shifter plate, between it and trans. It has a little trianlge metal flange there and the o ring. The 3 screws that hold the shift slide on also hold the flange on. :thumbs: Share this post Link to post Share on other sites
tractormanc120 0 #7 Posted January 24, 2011 well if you want to stop the tractor from running away you should either shut it off wich is a pain or replace the parts if you give me till tommorrow i can get you a number to a wheelhorse guy that has all those parts and caan ship them real reasonable Share this post Link to post Share on other sites
