kpinnc 18,314 #1 Posted May 9, 2008 Anyone know what fluid is reccomended for use in this system? Can you use regular motor oil as in the other hydro/ hydraulic systems? What would be least affected by the fluid heating up? Thanks! Kevin Share this post Link to post Share on other sites
linen beige 16 #2 Posted May 10, 2008 The manual says, in bold type, use wheel horse oil, part #4822 only. I don't know if that is an oil such as engine oil, or a hydro fluid. The manual for my Charger 9 says to use type A transmission "oil", what used to be called Transmission oil is now called transmission fluid, but type A is no longer made. Dexron II can be used instead. I have had to add fluid to my HY-2 and use a lighter viscosity hydraulic fluid. It doesn't seem to have hurt it. I'm sure one of the many other much more well educated guys can answer us both. Share this post Link to post Share on other sites
linen beige 16 #3 Posted May 10, 2008 The manual says, in bold type, use wheel horse oil, part #4822 only. I forgot to mention that Toro's customer service line could not help and referred me to my dealer. <_ and said to refer to my manual. :whistle: Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #4 Posted May 10, 2008 My HY-2 has power steering fluid in it. :WRS: Share this post Link to post Share on other sites
linen beige 16 #5 Posted May 10, 2008 My HY-2 has power steering fluid in it. Thanks TT! Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #6 Posted May 10, 2008 I don't know if that's what is SUPPOSED to be in it, but the guy I bought the tractor from thought it would be good because of the seal conditioner. Other than a very small leak at the cylinder seal, the system seems to work fine. I would imagine hydraulic jack oil would work too. :whistle: Share this post Link to post Share on other sites
Guest fireman #7 Posted March 21, 2009 Searched before I posted and found this thread. Has anyone found out anymore information as to what is the proper fluid to use in the HY-2? I am leaning to hydraulic jack oil. On the other hand, what TT said about the ATF and it's seal conditioner makes sense too. Share this post Link to post Share on other sites
linen beige 16 #8 Posted March 22, 2009 Just a few days ago I noticed that the instructions for installing the HY-3 refers to the part #4822 as hydraulic fluid. I still don't know if it was high, med., or low viscosity though. I also like the seal conditioner thought TT. Share this post Link to post Share on other sites
Docwheelhorse 2,929 #9 Posted March 23, 2009 All of my pumps on 953's/1054's (same as hy-2 or hy-3) have ATF in them... is it right???? I don't know---but it works and I think it would be better than jack oil that might not stand up to heat. Tony Share this post Link to post Share on other sites
Guest fireman #10 Posted March 23, 2009 Went to the hydraulics shop to get two news hoses made for the HY-2. Showed the manual and asked about what fluid to use. He recommended using the ATF. He said the hydraulic jack oil is not really designed to take the high temperatures that the pump will develope. Share this post Link to post Share on other sites
bowtieguy 334 #11 Posted March 23, 2009 Hey Jim in KY...I still buy Type A tuff.....from MFA Oil CO....just bought a case of it last year and it is still a standard product....farmers still use it so guess that is why they still carry it....at least Type A is what it is labeled as....Frank in MO :omg: Share this post Link to post Share on other sites
WheelHorse_of_course 101 #12 Posted March 23, 2009 I would suspect in addition to temperature resistance the other important properies would be non-foaming and resistance to cavitation. But I really don't know... :omg: Share this post Link to post Share on other sites
linen beige 16 #13 Posted March 24, 2009 Hey Jim in KY...I still buy Type A tuff.....from MFA Oil CO....just bought a case of it last year and it is still a standard product....farmers still use it so guess that is why they still carry it....at least Type A is what it is labeled as....Frank in MO Hey! I knew that too. I run plain hydraulic fluid in mine. I have run it for several hours at a time with the pump getting pretty hot, but I've had no problems with the hydro fluid foaming or loosing performance after getting hot. But I do think I may switch to power steering fluid if I ever open it up again. I like the idea of the seal conditioners in the PSF. Share this post Link to post Share on other sites
gumshoes 205 #14 Posted June 13, 2015 How much oil does the HY-2 kit hold when empty. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #15 Posted June 13, 2015 (edited) I wondered if the capacity could be found in the Lubrication chartshttp://www.wheelhorseforum.com/files/file/1085-chart-lubrication-recommendations-and-capacities-33-pages-492-0392pdf/and it is for the 1960-1965 modelsGarryAdding 1962-1963 model HY-2 and 1964-1965 HY-3 to aid future searches. Edited June 13, 2015 by gwest_ca Share this post Link to post Share on other sites
adsm08 4,516 #16 Posted May 3, 2019 I know this is an old thread, but my question is relevant to the topic at hand here. I have to open up my HY-3 to reseal it, and I will be replacing the fluid at that time. Based on what is in here, is it safe to say that DEX II/III is safe to use? If so I'd really rather use that since I buy it in bulk as all of my vehicle transmissions and PS systems us it. 1 Share this post Link to post Share on other sites
953 nut 66,374 #17 Posted May 4, 2019 I have been running Dextron in the pump on my 953 for years with no problem. It is the same as the HY-2. Share this post Link to post Share on other sites
adsm08 4,516 #18 Posted May 4, 2019 OK, I just wanted to make sure. I know that not all hydraulic systems can stand up to ATF. My father in law ruined one of his best floor jacks by topping it off with ATF because his neighbor said it would be OK, make the leak 10X worse. Share this post Link to post Share on other sites
