rustbucket 4 #1 Posted May 9, 2008 I found this odd little trailer with the GT-14 and am wondering if it was a WH made trailer or some other manufacture from from around the GT-14's time frame. Attached Image (Click thumbnail to expand) Share this post Link to post Share on other sites
rustbucket 4 #2 Posted May 10, 2008 is it worth restoring i think its made of aluminum as it is very light but strong as heck nees a bit of tweaking and some little work here and there but i think it will clean up at least somewhat good. Share this post Link to post Share on other sites
kj4kicks 154 #3 Posted May 10, 2008 Jason, I don't think it's a WH piece, BUT, if it will do what you want it to do, then fix it up and give it a new life! Share this post Link to post Share on other sites
rustbucket 4 #4 Posted May 12, 2008 i'll be looking into it once the GT-14 is squared away a bit better and has at least some more primer on it other then just the nose in sections. i will need to change the trailors hitch system to a more common one as well as possably re streighten the rear axle and repaint it and new skins for the rims. Share this post Link to post Share on other sites
