persof 14 #1 Posted January 17, 2011 The PTO clutch in my recently aquired C161 is shot! I could see that the friction material was worn away but when I replaced the friction disk the cast part with the pully groves has a gouge all the way around it. Could this be resurfaced on a lathe? Thanks Francis Share this post Link to post Share on other sites
Kelly 1,035 #2 Posted January 17, 2011 I've tosed better ones, I'm sure it could be saved, but at what cost? PTO bells can be had for less than $25 And I see they had the early small disc and the newer large bell, I'd be sure to get the newer large disc and bell, not sure you can get the old 5" I think disc. Share this post Link to post Share on other sites
MikesRJ 558 #3 Posted January 17, 2011 Kelly'll sell you one for $25! :banghead: Share this post Link to post Share on other sites
persof 14 #4 Posted January 17, 2011 That picture is distorted. The diameters are the same. Where can I get a good one? Thanks Francis Share this post Link to post Share on other sites
tmessenger 0 #5 Posted January 17, 2011 That picture is distorted. The diameters are the same. Where can I get a good one? Thanks Francis I have a complete assembly with the bell and good disk in the for sale section under C-120 but it may be spoken for, if it doesn't work out I'll let you know. Tim Share this post Link to post Share on other sites
Kelly 1,035 #6 Posted January 17, 2011 Mike I have a few extra ones here, I was just saying a nice one with good bearings and all will bring up to $25 I'm sure you can get them cheaper, but going by the wear pattern on the PTO bell it did not go to the outer edge, or even close to the inner edge the newer disc will, and will not be riveted, it will be a bonded disc. Share this post Link to post Share on other sites
persof 14 #7 Posted January 17, 2011 Tim, Are the part numbers the same throughout the C series tractors and engine sizes? Thanks FrancisThanks Share this post Link to post Share on other sites
persof 14 #8 Posted January 19, 2011 Kelly, Both the friction disk and the PTO bell are 6.75" in diameter. If you have a "good" one that you might want to part with let me know. How do you change the bearing in side??? Thanks Francis Share this post Link to post Share on other sites
Kelly 1,035 #9 Posted January 19, 2011 I should have a PTO bell, not sure about a good disc. send me a PM. Share this post Link to post Share on other sites
