elixir20 1 #1 Posted January 16, 2011 I was just out doing some more clean-up after the recent 18" of snow we got, and broke the 854 The Right tire freewheels now..What did I do, and more importantly how do I fix it? The boss isn't gonna be happy :banghead: Share this post Link to post Share on other sites
littleredrider 409 #2 Posted January 16, 2011 Probly the shear pin that goes on the steering arm to the spindle.... Share this post Link to post Share on other sites
elixir20 1 #3 Posted January 16, 2011 That doesn't sound too $$$. How do I start the fix... Share this post Link to post Share on other sites
JimD 3,347 #4 Posted January 16, 2011 Unhook the tie rod, get the spindle lined up with the steering arm and drive the pin out with the correct size pin punch, then drive in a new pin. Share this post Link to post Share on other sites
neil 2,410 #5 Posted January 16, 2011 if you do as the guys above say you should cure your problem should be an easy fix doesnt look to serious Share this post Link to post Share on other sites
HorseFixer 2,013 #6 Posted January 16, 2011 Oh man that tractor is really messed up You need to give it to me! :banghead: Share this post Link to post Share on other sites
elixir20 1 #7 Posted January 16, 2011 Thanks guys. I'll give it a go. Is the pin anything special? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #8 Posted January 16, 2011 It should actually have double roll pins in that hole. The outside pin is 1/4" X 1 3/8" with a 5/32" x 1 3/8" pin driven through the inside of the larger pin for strength. Cheap (Taiwan/China) roll pins don't amount to squat - use "quality" roll pins or buy the OEM pieces from a Toro dealer. 933216 & 933174 are the OEM part numbers. If the holes are worn, you can drill them out and installer larger roll pins - if it hasn't already been done. Share this post Link to post Share on other sites
elixir20 1 #9 Posted January 16, 2011 TT-thanks for the info. I'll call my dealer and get the correct one Tuersday. Share this post Link to post Share on other sites
Coadster32 793 #10 Posted January 17, 2011 Oh man that tractor is really messed up You need to give it to me! Duke, you trying to snake a newbie out of another roundhood? :banghead: Share this post Link to post Share on other sites
HorseFixer 2,013 #11 Posted January 17, 2011 Oh man that tractor is really messed up Share this post Link to post Share on other sites
d180man 5 #12 Posted January 17, 2011 Hi pin should fix it ! nice tractor !! :ROTF: Share this post Link to post Share on other sites
elixir20 1 #13 Posted January 17, 2011 OK boys, calm down. I may be a newbie, but the 854 has a good home and is not going anywhere. :banghead: Share this post Link to post Share on other sites
Coadster32 793 #14 Posted January 17, 2011 OK boys, calm down. I may be a newbie, but the 854 has a good home and is not going anywhere. Exactly what we wanted to hear! I agree on the roll pin being the problem. Share this post Link to post Share on other sites
Kelly 1,033 #15 Posted January 18, 2011 I would pull the steering arm off to take a peek at the hole in the spindle, most are worn, almost slots, and would be best to drill it over size. Share this post Link to post Share on other sites
smoreau 658 #16 Posted January 18, 2011 I would pull the steering arm off to take a peek at the hole in the spindle, most are worn, almost slots, and would be best to drill it over size. I agree with Kelly, you should pull the arm off and see if the hole is warn. you don't want to have this happen again. very nice tractor and good luck :banghead: Share this post Link to post Share on other sites
