BairleaFarm 344 #1 Posted May 7, 2008 I should have it drivable tomorrow if my hub gets here. Dont bash me me on the specifics ill explain why i did what when i get it finished Share this post Link to post Share on other sites
Sparky-(Admin) 24,848 #2 Posted May 8, 2008 Well if thats the same tractor as your Avatar then its coming out just fine. Mike.............. Share this post Link to post Share on other sites
WheelHorse_of_course 100 #3 Posted May 8, 2008 :whistle: David, no need to explain. The main thing is that it will soon be ready to work. I hope you are having fun. Remember, the more mashed knuckles fixing it up, the more you will enjoy using her! :D Share this post Link to post Share on other sites
CasualObserver 3,415 #4 Posted May 8, 2008 Lookin good David! Your new hub will fit right in. Looks like you do have quite a fight on your hands to get that other one off though! Good luck! Hope you've been hitting it with PB Blaster or Kroil at least once a day. That will work wonders. I'd think that your best bet would be to try to grip the hub somehow and drive the axle out of it rather than trying to pull the hub? Not sure. :whistle: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #5 Posted May 8, 2008 When they look like that , it's easiest to split them parallel with the axle using a 1/8" thick cut-off wheel on a small angle grinder. Do it on the side opposite the keyway and if the axle gets nicked a little, it doesn't hurt a thing. :whistle: Share this post Link to post Share on other sites
BairleaFarm 344 #6 Posted May 8, 2008 it's easiest to split them parallel with the axle using a 1/8" thick cut-off wheel on a small angle grinder. bingo it soaked in blaster for over a week and still wouldnt budge. Share this post Link to post Share on other sites
BairleaFarm 344 #7 Posted May 10, 2008 Does this part come off? not the whole pulley but just that part the clutch rides on. I dont like the tires but they got me rolling. My replacement hub is to big for the center of the stock tires. It looks better than the pictures show. I still need to fix the fender plate and get a new seat. The hood has its first coat but needs one more before i mount it. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #8 Posted May 10, 2008 Does this part come off? not the whole pulley but just that part the clutch rides on. Yes, it is supposed to be a slip-fit on the crankshaft. I'd say yours is "rust-welded" in place though. Every one that I reassemble gets a light coating of anti-seize just for that particular reason. :whistle: Share this post Link to post Share on other sites
BairleaFarm 344 #9 Posted May 10, 2008 Thats what i thought. It doesn't look like there is any room to get a puller of any kind on it. Share this post Link to post Share on other sites
CHARGER9AUTO 3 #10 Posted May 10, 2008 I should have it drivable tomorrow if my hub gets here. Dont bash me me on the specifics ill explain why i did what when i get it finished DuramaxDavid, I purchased my '73 Wheel Horse 8 4 SPEED at the '06 Wheel Horse show in PA The pewrson who used the tractor mowed his lawn with it always stored it in his Garage and maintained it every Spring . I replaced the decals and front tires with rims I'd ordered from NORTHERN TOOL - EQUIPMENT I picked up some 20x8.00-10 rear wheels they needed new valve stems because the old were broken on the rims . it runs like a Champ with no smoke or knock . Ben Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #11 Posted May 10, 2008 Thats what i thought. It doesn't look like there is any room to get a puller of any kind on it. Nope -- you can't get a puller on it. Do you have any PB Blaster? Spray some back the keyway in the crankshaft and let it soak for a while. If you don't plan on reusing the PTO bearing race, you can try tapping around the outside of it to help loosen it up. OR..... put a pipe wrench on it and smack the handle with a hammer. (you didn't hear that from me though! ) Share this post Link to post Share on other sites
BairleaFarm 344 #12 Posted May 10, 2008 Clean lookin tractor. I dontknow if ill use it or not. Im not to worried about it but I think ill leave it instead of breaking something. Share this post Link to post Share on other sites
CHARGER9AUTO 3 #13 Posted May 10, 2008 Clean lookin tractor. I dontknow if ill use it or not. Im not to worried about it but I think ill leave it instead of breaking something. Yeah Thanks, I use mine all the time for yard work . Ben Share this post Link to post Share on other sites
