CTPATRIOT 12 #1 Posted January 6, 2011 Where they solid or rubber mounted? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted January 6, 2011 Rubber Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #3 Posted January 6, 2011 I believe all the blackhoods were rubber mounted ?? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted January 6, 2011 I believe all the blackhoods were rubber mounted ?? Nope. Guess which one wasn't. :banghead: Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #5 Posted January 6, 2011 Sorry.. I knew this... C175 and C195 :banghead: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted January 6, 2011 The C-195 is the only one. Share this post Link to post Share on other sites
CTPATRIOT 12 #7 Posted January 6, 2011 The C-85 i have is solid mounted and looks factory.Would it be an older engine? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #8 Posted January 6, 2011 :banghead: Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #10 Posted January 6, 2011 I think I have to agree that is factory. It has been a very long day for me and I am not thinking clear... I though the C85 was solid mounted. Jeff (wheelhorse85) had one that I believe is solid mount. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #11 Posted January 6, 2011 My C-85 had a rubber-mounted engine: Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #12 Posted January 6, 2011 Terry, I looked at that in the pic gallery. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #13 Posted January 6, 2011 I was just being a seeing eye dog for the others, Steve. :banghead: Share this post Link to post Share on other sites
wheelhorsec85 5 #14 Posted January 6, 2011 I think I have to agree that is factory. It has been a very long day for me and I am not thinking clear... I though the C85 was solid mounted. Jeff (wheelhorse85) had one that I believe is solid mount. hay Steve , the c85 that i owned for 10 years was my first wheel horse . and it was rubber mounted . i like the black hood except for it being rubber mounted . but all c85s came from the factory rubber mounted . or should have . i took a c101 and made it a solid mount engine . and was easy to do . so all you would need is a older 8 hp kohler to do this to a c85 . i have a question for Shaun . #1 is that how you spell your name ? . and #2 is or was the 8 hp kohler on your c85 red at one time ???. if it was red it is a older engine . :ROTF: Share this post Link to post Share on other sites
CTPATRIOT 12 #15 Posted January 6, 2011 (SHAWN)The engine is black.,looks original.I'll check it out better and post some engine pics today. Share this post Link to post Share on other sites
CTPATRIOT 12 #16 Posted January 6, 2011 The engine has a 1982 serial number,i'm guessing the tractor is an "82 or "83.The serial number tag on the tractor is blank.Here are the pics. Share this post Link to post Share on other sites
rmaynard 16,586 #17 Posted January 6, 2011 Looking at the picture above, and then looking at the 1983 C-85 parts diagram, what you see (the solid mount) appears to be standard for that year. Share this post Link to post Share on other sites
CTPATRIOT 12 #18 Posted January 6, 2011 Looking at the picture above, and then looking at the 1983 C-85 parts diagram, what you see (the solid mount) appears to be standard for that year. Interesting,was it a 1983 only thing for the C-85? Share this post Link to post Share on other sites
dgjks6 8 #19 Posted January 6, 2011 I'll be darned. According to the Toro Master Parts viewer that is a stock engine mount for 1983 only. Therefore your tractor is a 1983 - 11-08K801. Share this post Link to post Share on other sites
WH854 45 #20 Posted January 7, 2011 Well I must be seeing things that engine looks bigger than an 8hp could it be a factory Johnny Cash tractor Chas Share this post Link to post Share on other sites
can whlvr 994 #21 Posted January 7, 2011 in talking about the rubber mounted engines,i wonder why wheelhorse stopped using that setup,i have tractors that dont have it and one that does,it seems smooth,no vibrations,so do u guys think it was a money thing or did they encur problems with the mounts? Share this post Link to post Share on other sites
dgjks6 8 #22 Posted January 7, 2011 The guy who machined my engine talked a lot about this. He said on the Kohler's with the balance gears and the rubber mounts there were problems. If the balance gears were left out, or put in incorrectly, on tractors with rubber mounts, then the tractors would shake uncontrollably. He recommended that if leaving the balance gears out, then mount the engine directly to the frame. Share this post Link to post Share on other sites
JimD 3,347 #23 Posted January 7, 2011 Looking at the pictures above, there are spacers between the engine and the riser plate mount. I haven't seen this before. Are the spacers rubber, or metal? Did Wheel Horse reinvent the wheel here and change from the cradle mount? :banghead: Share this post Link to post Share on other sites
CTPATRIOT 12 #24 Posted January 7, 2011 Looking at the pictures above, there are spacers between the engine and the riser plate mount. I haven't seen this before. Are the spacers rubber, or metal? Did Wheel Horse reinvent the wheel here and change from the cradle mount? All steel,NO rubber at all . Share this post Link to post Share on other sites
