sorekiwi 761 #1 Posted May 6, 2008 Had a severe electrical failure on the B80 while cutting the grass on Sunday. What happened was the rod came out and nailed the starter motor. Here's the pictures: Daylight from the iside of the motor: Most of the connecting rod: The jigsaw puzzle: They always go really well right before they blow up... Actually what really pi$$es me off is that with 5 tractors, I didnt have anything to finish cutting the grass! :whistle: Share this post Link to post Share on other sites
Rollerman 290 #2 Posted May 7, 2008 Mike thats a pretty big hole for a K181. If it was an aluminium B&S or tucky I'd say thats normal.... Serious though....sorry about your engine failure & hope you can get the parts around for a repair. Share this post Link to post Share on other sites
WheelHorse_of_course 100 #3 Posted May 7, 2008 Bummer Now, assuming you would rebuild it if there was no hole in the block..... ... this could be a real test of JB Weld! So far my limited testing has shown it to be impressive. :whistle: Share this post Link to post Share on other sites
sorekiwi 761 #4 Posted May 7, 2008 Now, assuming you would rebuild it if there was no hole in the block..... ... this could be a real test of JB Weld! So far my limited testing has shown it to be impressive. Actually I am toying with the idea of welding it up... Almost 20 years ago I repaired some engine blocks with arc welding (preheat and slow cool etc etc), but a few months ago I mig welded a broken cast iron bracket on the lathe at work and thats still holding up well. The Kohler block is pretty thin through there, I think it could work. I have another block, but its one of the early small bore K161's and needs boring. I'm very tempted to weld all the pieces back in, polish the crank, put another rod in it and see how long it lasts. :WRS: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted May 7, 2008 Gee.... wonder if that one needs a camshaft too? If you were only closer, Mike..... I could fix you right up! :WRS: Share this post Link to post Share on other sites
sorekiwi 761 #6 Posted May 7, 2008 Gee.... wonder if that one needs a camshaft too? I dont think the cam took a hit, not a mark on it. I think the rod broke at the top first, then that poked the hole in the block, and then thats what broke the big end apart. If the big end of the rod had broken first I dont think the hole in the side would've been so big. There is one "punch mark" from the rod right in the middle of the pieces that broke out. Its funny, I've been a race car mechanic for 20 years, have probably changed 1000 engines, and seen 100 blown up. But this is the first one I've been directly looking at when it popped. Kinda cool really, reminded me of those slow motion video's of a bullet hitting an apple or something. Share this post Link to post Share on other sites
BairleaFarm 340 #7 Posted May 7, 2008 Ive had my tractor completely apart the last few days painting it. I had a hole about that size in the same place at one time. Someone fixed it and it doesn't leak so not all is lost with that block. Share this post Link to post Share on other sites
kj4kicks 154 #8 Posted May 7, 2008 Yep, as electrical failures go, that was a bad one ! Hope you can get it all back together since you were able to find the pieces. Share this post Link to post Share on other sites
illinilefttackle 399 #9 Posted May 7, 2008 SOREKIWI-Years ago I repaired Automatic Transmission case by welding it in a stitch fashion-then sealing it with and epoxy that had aluminum particles it it-still on the road today-Good Luck!-AL :whistle: Share this post Link to post Share on other sites
linen beige 15 #10 Posted May 7, 2008 What happened was the rod came out and nailed the starter motor. OK, somebody's gotta ask, Did you find the starter motor? Share this post Link to post Share on other sites
Rollerman 290 #11 Posted May 7, 2008 If you were only closer, Mike..... I could fix you right up! Like wise TT...wait we are some what close.... OK, somebody's gotta ask, Did you find the starter motor? Jim it should be landing soon. :WRS: Share this post Link to post Share on other sites
DMESS 24 #12 Posted May 7, 2008 You didn't take any shrapnel from that blast did you? Can't say I've seen one go like that. Poor starter did its job and was just hanging out as an innocent bystander! :WRS: Share this post Link to post Share on other sites
WheelHorse_of_course 100 #13 Posted May 8, 2008 Go ahead and weld her up! Share this post Link to post Share on other sites
sorekiwi 761 #14 Posted May 8, 2008 You didn't take any shrapnel from that blast did you? Imagine if it was an RJ or Suburban and it let go like that... be more than just a Ball Burner! :WRS: Share this post Link to post Share on other sites
linen beige 15 #15 Posted May 8, 2008 Jim it should be landing soon. :WRS: Share this post Link to post Share on other sites
Kelly 1,033 #16 Posted May 8, 2008 I welded a car block with a mig, then coated it with JB weld to seal it. It was in the lifter valley on a SBC both sides full legnth of the block, and ran it as a derby motor for years, got VERY hot many times finally a rod let go. I say weld it up, thats not a high stress area, normally. Share this post Link to post Share on other sites
sorekiwi 761 #17 Posted May 9, 2008 I say weld it up, thats not a high stress area, normally. Yeah, thats what I'm going to do. I'll post pictures if I'm not too ashamed of it! It may be a week or so - I've got way too many 1/2 finished projects lying round so have to organize my life a little before I pull the rest of the motor apart! Hmmm.... I wonder if I could change the rod from the bottom, flush out the case with brake-clean, weld the case, and put it together. Then I wouldnt even need to buy a head gasket!! :whistle: Share this post Link to post Share on other sites
