wheel horse 312 0 #1 Posted January 4, 2011 :ROTF: will a 16x6.50-8 wheel and tire fit a 1992 312-8 speed if so what would i have to do to get it to fit :thumbs: Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted January 4, 2011 As long as it is a WH wheel it will fit, I'm guessing yours has 6" wheels, so that means your tractor has the long spindles, the 8" will fit the long spindles but the nose will set a bit higher, you can swap to the standard short spindle, one from many tractors will fit C's 300, 400, ect..... now if you have a 37" SD deck you will have issues with the tire hitting the deck with 8" wheels, but that is the only deck with that issue. Share this post Link to post Share on other sites
case442 132 #3 Posted January 5, 2011 Hi Kelly, I did the same with my 312-8, is there a way too adjust the deck now? the front anti scalp wheels no longer run on the ground. Thank you, Mike Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted January 5, 2011 Did you put the short spindles on?? if you did it should set at the same height as before Share this post Link to post Share on other sites
wheel horse 312 0 #5 Posted January 5, 2011 my 312-8 front tiers that are on it right now is 15x6.00-6 Share this post Link to post Share on other sites
dgjks6 8 #6 Posted January 5, 2011 Are you running the 37inch 2 blade deck? I don't think the anti scalp rollers should hit the ground, the front of the deck is suspended from the tach a matic and the rear wheels ride on the ground. You can adjust the deck height with the rear wheels and there are 2 adjuster bars on the 37 inch deck to get it level. But as Kelly said, if you are running the 37 inch deck with 8 inch wheels, the front tires will contact the deck when turning. The 36 inch rear and side discharge, and the 42 rear and side discharge, and the 48 inch deck should fit without a problem. Share this post Link to post Share on other sites
wheel horse 312 0 #7 Posted January 5, 2011 i think i have the 48" deck :thumbs: Share this post Link to post Share on other sites
dgjks6 8 #8 Posted January 5, 2011 here's a good link with pics. Sorry took a while to find. http://www.wheelhorseforum.com/index.php?...ch+front+wheels Share this post Link to post Share on other sites
C-Series14 15 #9 Posted January 5, 2011 i think i have the 48" deck Measure a blade, that will tell... Share this post Link to post Share on other sites
can whlvr 994 #10 Posted January 6, 2011 i did this swap on my 308,i changed the spindles from a 70s c and they fit and now my wheels bolt on instead of a cotter pin. Share this post Link to post Share on other sites
wheel horse 312 0 #11 Posted January 9, 2011 the wills and tiers are off a work horse gt 1142 :banghead: Share this post Link to post Share on other sites
