stevasaurus 23,652 #1 Posted January 4, 2011 Does anyone here know the correct way to bench test a starter?? I have to admit, that I do not, and I do not want to guess. :banghead: Share this post Link to post Share on other sites
wheelly 0 #2 Posted January 4, 2011 Just hook your charger or battery possitive to the possitive post on starter. Then touch the negative to the starter housing. It should kick over. If the charger is a small one it my not have enough amps to turn it over. Share this post Link to post Share on other sites
rmaynard 16,989 #3 Posted January 4, 2011 Clamp it in a vise first. Those motors have a bit of kick. Share this post Link to post Share on other sites
puddlejumper 67 #4 Posted January 4, 2011 Steve I know your a do it myself kind of guy. But autoparts store should check it for free, That way you will know if its drawing to many amps or dragging excessive. Share this post Link to post Share on other sites
wheelhorse656 20 #5 Posted January 4, 2011 hook your charger up. then put the positive on the post clamp the the negitve on what ever you can that does not move then hold it down on a desk or clamp it in a vise than turn on charger if id does not kick then its bad! hope this helps! :banghead: Share this post Link to post Share on other sites
Kelly 1,038 #6 Posted January 4, 2011 Even if it turns using this method, does not mean it is good, chances are good that it is, but with a load like turning a engine with compression might show bad brushes, or other issues. Share this post Link to post Share on other sites
flyovrcntry 115 #7 Posted January 4, 2011 Just hook a battery to it if it kicks pretty good its prob good.Its not that technical,it either works or it don't. Share this post Link to post Share on other sites
stevasaurus 23,652 #8 Posted January 4, 2011 Thanks guys...kind of thought that was the way it worked. Think I will try Cliff's idea first and take it to an auto parts store...then do the vise and battery thingy. :banghead: Share this post Link to post Share on other sites
