formariz 12,381 #1 Posted January 3, 2011 Since the tombstone weight topic has come up recently and I have been looking through my stock looking for a bracket I finally decided to put them to use on my Electro. Used an odd ball hitch that came with another tractor upside down attached to the regular hitch and there it is.Simple and quick with no fabrication. Hope it is not a bad thing to have a tombstone(or two) upside down . Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted January 3, 2011 You know not everyone has TWO tombstone weights to play with, but that is a good idea, they don't hit the ground do they?? Share this post Link to post Share on other sites
danjmah 74 #3 Posted January 3, 2011 Nice! Just curious how much does one Tombstone weigh? thx. Share this post Link to post Share on other sites
Brrly1 1,146 #4 Posted January 3, 2011 They weigh around 53lbs give or take. See Ya, Bye Burly :ychain: Share this post Link to post Share on other sites
MikesRJ 563 #5 Posted January 3, 2011 As much as I like the idea, my initial reaction was a sinking of my heart! Good idea though. :ychain: Share this post Link to post Share on other sites
clintonnut 127 #6 Posted January 3, 2011 Cas, You should make a mold out of plaster and cast those in lead! Would probably weigh close to 140 lbs Charlie Share this post Link to post Share on other sites
64s 83 #7 Posted January 3, 2011 Hope it is not a bad thing to have a tombstone(or two) upside down . If you hang them upside down, all of the luck will run out. :banghead: Share this post Link to post Share on other sites
btrrg1969 11 #8 Posted January 3, 2011 that should help get traction :banghead: Share this post Link to post Share on other sites
formariz 12,381 #9 Posted January 3, 2011 You know not everyone has TWO tombstone weights to play with, but that is a good idea, they don't hit the ground do they?? They are actually 6" off the ground. Well, its not that I have TWO tombstone weights to play with, but that I could only fit two back there :banghead: Share this post Link to post Share on other sites
formariz 12,381 #10 Posted January 4, 2011 As much as I like the idea, my initial reaction was a sinking of my heart! Good idea though. Thanks Mike.It actually took me longer to decide to do it than to actually mount them. But then, no harm done to the weights since they are intact and in the winter they would have been weighing down tractors that are not moving so this way they pull their own weight. Is that right? :banghead: Share this post Link to post Share on other sites
formariz 12,381 #11 Posted January 4, 2011 Hope it is not a bad thing to have a tombstone(or two) upside down Share this post Link to post Share on other sites
