MalMac 1,333 #1 Posted December 28, 2010 Ok while we are talking lights, how much is too much on a 520H. I don't think you could put desert lights on it like you would a off road vehicle. What can the tractor handle with out putting too much load on the electrical system? Share this post Link to post Share on other sites
Duff 206 #2 Posted December 28, 2010 Ok while we are talking lights, how much is too much on a 520H. I don't think you could put desert lights on it like you would a off road vehicle. What can the tractor handle with out putting too much load on the electrical system? Just a thought here....if you look into high intensity LED's you can probably load her up pretty good! Duff :ychain: Share this post Link to post Share on other sites
edwroy 138 #3 Posted December 28, 2010 I put a set of 50 watt driving light onmy 520. The lights pulled to much on the system. So, changed the bulbs to 25 W. Works great. edroy Share this post Link to post Share on other sites
WH nut 553 #4 Posted December 28, 2010 Watts Divided by volts will tell you how many amps they will draw, then go from there Share this post Link to post Share on other sites
