tranders 0 #1 Posted December 25, 2010 Good morning and Merry Christmas. The problem I'm having with my Raider 10 is after working (pushing snow) the engine doesn't want to idle down. The linkage is moving freely. The only way to get it to idle down is slowly put a load on the engine,then it will idle back down. Thanks for the help. Share this post Link to post Share on other sites
rmaynard 16,537 #2 Posted December 25, 2010 Have you checked to make sure that the governor linkage is tight and adjusted properly? Share this post Link to post Share on other sites
Indy w h 5 #3 Posted December 25, 2010 It could also be froze open Indy Share this post Link to post Share on other sites
MikesRJ 558 #4 Posted December 25, 2010 Did you look at the governor arm? Share this post Link to post Share on other sites
rickv1957 76 #5 Posted December 25, 2010 Maybe carb needs adjustment. Share this post Link to post Share on other sites
MikesRJ 558 #6 Posted December 25, 2010 T-Mo did a great job with a Kohler Carburetor Rebuild procedure. It may be useful to you: http://www.mywheelhorse.com/graphics/file/...etorRebuild.pdf Share this post Link to post Share on other sites
tranders 0 #7 Posted December 26, 2010 Thanks for all the advice. Heading out to the garage to start tinkering. Will let you know how it works out. Share this post Link to post Share on other sites
tranders 0 #8 Posted December 26, 2010 WooHoo... Fixed the problem. After double and triple checking all adjustments on carb with no change, I decided to swap out fuel pumps. Runs like a champ now. No hesitation on throttle up and idles back down normally. I'm not real happy the new pump is plastic,but heck it's running good. Thanks again for the help! Share this post Link to post Share on other sites
Kelly 1,033 #9 Posted December 27, 2010 :ychain: fuel pump?? unless engine was starved for fuel, running lean, but normally they just quit. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #10 Posted December 27, 2010 Yeah..... he musta bumped whatever was sticking on the linkage when he changed the fuel pump. :ychain: Share this post Link to post Share on other sites
tranders 0 #11 Posted December 28, 2010 That's a possibility. :ychain: Share this post Link to post Share on other sites
