Matthew hurst 1 #1 Posted December 22, 2010 The fuel pump seal on my c141 just want to leak, I put a new seal in and it still leak. About 10 min after I shut it off it start to leak. :ychain: Share this post Link to post Share on other sites
Kelly 1,037 #2 Posted December 22, 2010 The pump to block seal? leaking oil? or gas? Share this post Link to post Share on other sites
Kelly 1,037 #4 Posted December 22, 2010 I've had problems with cheap gaskets not being as thick as Kohler ones and they leak, I've doubled the gaskets with sealer between them and had good luck, also check to see the pump body is not cracked near the mounting holes. Share this post Link to post Share on other sites
Matthew hurst 1 #5 Posted December 22, 2010 Thanks Kelly :ychain: Share this post Link to post Share on other sites
