porkchop 1 #1 Posted December 22, 2010 My lift cylinder on the 16 auto is leaking. Can these be rebuilt?? Doe's anyone know any part numbers for a kit or seals?? in advance. Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted December 22, 2010 I believe that is a welded unit, probably easier to get a used one, I know if it is the welded one you can chuck it up in a lath and cut it open put new seals in and weld it back up, but like I said probably easier to get another/ Share this post Link to post Share on other sites
wh79d160 52 #3 Posted December 22, 2010 When I bought my 1st D the PO said he had one of the lift cyclinders rebuilt. They cut the end off & welded it back on. Must have got it too hot , it leaked. Got a used one off ebay. Good Luck :ychain: Share this post Link to post Share on other sites
MikesRJ 558 #4 Posted December 22, 2010 Any good hydraulics house, if you call them on the phone, could match the cylinder from dimensions you give them. Share this post Link to post Share on other sites
MikesRJ 558 #5 Posted December 22, 2010 I looked up the part numbers for the original cylinder. Unfortunately both are discontinued. They are 6618 and 105254 if that helps any. Share this post Link to post Share on other sites
porkchop 1 #6 Posted December 23, 2010 Thanks for all the suggestions. I was wondering if the one for a newer tractor would be the same or doe's anyone have one they want to sell? Share this post Link to post Share on other sites
Kelly 1,033 #7 Posted December 23, 2010 I know the hose location is diff. from the old to the new style, old are a bit off to the side, the newer ones are staight on top. Share this post Link to post Share on other sites
