c81horse 0 #1 Posted December 21, 2010 I just got me some Plastic/Concrete wheel weights four to be Exact two are a matching set 35lbs The other two are mix matched 35lbs and the other 55lbs I wonder how 35lbs will work on one side and 55lbs on the other I mean for four wheel weights 50$ i couldent pass up that deal the matching set is worth that :ychain: Share this post Link to post Share on other sites
Coadster32 793 #2 Posted December 21, 2010 A few guys here run weights inside and out. (me being one of them). :ychain: Share this post Link to post Share on other sites
Don1977 606 #3 Posted December 21, 2010 I believe they need to be equal in weight or light one will spin more easily. If your plowing your garden with a turn plow you can use more weight on the wheel that is not down in the furrow. Share this post Link to post Share on other sites
