CTPATRIOT
C-120 front wheel bearings needed!
CTPATRIOT
My "77 C-120 is super tight everywhere except the front wheel bearings,they are very worn out!The bearings and spindles were covered in grease,so that wasn't the problem.What's my cheapest way out for bearings right now?I did a bunch of work on the tractor today.Air filter,spark plug,gear oil,grease ect..I want to mount the plow/chains tomorrow,but want to fix this first.
Kelly
Cheapest is bearings from TSC, or other store like that, here they have them for about $4 each, 1 3/8" od x 3/4" id they are cheap stamped tin bearings much like the orig., I like the sealed bearings you can get from bearing dealers or I get mine from a local JD dealer but they are about $9 each, but I don't have to grease them, they are machined steel, much nicer.
CTPATRIOT
Thanks for the size,i'll get some at TSC tomorrow :ychain: .
WheelHorse_of_course
Using the generic size you probably can get them from manufacturer's Supply (might be in the mini-bike parts section)
:D :D
HorseFixer
Contact Motion Industries and get a good bearing like the Heim RF 122214AP :ychain: Problem Solved.
CTPATRIOT
I'll order some good ones later on.I need this rig done for Sunday/Monday,we may get a storm :ychain: .Another question(havent removed all the goop),what holds the front wheels on?Also,it's missing the bearing/hub caps,what size are those?(TSC also?)Thanks for the help.
Kelly
Clean the crud off, and there will be a bolt and washer or a snap ring, or E clip, or a cotter pin, they used many things to hold the front wheels on, but I'll guess on yours to be a snap ring, as for the covers see our vender here Glenn the hood ornament guy, he makes them, or your local Toro dealer they have the plain ones.
Butch
Duke are both sides sealed and you pop the inner seal out so grease can reach it. During some of my wheel endeavors I have noticed the hub full of grease and the bearings have seals on both sizes. If the hub of the wheel has a grease zert then to me it means that the inner side bearing must not have a seal.
Are those bearing sizes pretty much the same for all WH wheels? It seems pretty common.
Kelly
I don't pull the seal, they come greased from the factory and will last years and years, and yes the same size bearing fits many of the WH front wheels, if not most of them.
