Shuboxlover
Will this still work???
Shuboxlover
So I took this starter apart to clean and inspect it, and when I was putting back together....I dropped the dang thing :D:ychain:
My question is.....will it still be functional with part of that brush missing....
I have the piece that broke off, would it do any good to try and glue it back together :D
Kelly
I'm going to say it might work but will not have any power to turn the engine, and no you can't glue it unless you have conductive glue.
wh79d160
I believe the broken part is the part that goes against the armature. I think NASA makes a special kind of high conductor glue that you could use. Know anybody @ Cape Canavrel? I think it's time for a new brush set. Throw it in a box & wait till spring. You got enough tractors ready to go. Take you ADD meds & finish the inside of that building. :D :ychain:
Don1977
From the looks of that other brush I think you need a new set anyway.
Trouty56
Maybe spend a couple bucks more and buy a complete one from the auction site or better yet a new after market starter. I've seen them for around 60 or so. The magnet is cracked and now you need brushes.
Here is a starter for example for 44 before shipping. Maybe these aren't any good. Don't know but it is an alternative.
Shuboxlover
Take you ADD meds & finish the inside of that building. :D:D
Hey Hey Hey!!!!! I've gotten a little distracted lately..... B)
I actually just pulled the electrical permit this morning.....although, it might already be wired :D:hide::ychain:
Hopefully get it inspected next week....
start insulating the week after, and then the sheet rock.....hopefully by the middle of January it will be insulated, dry walled (not finished though), and all the lights and stuff up, then the plumbing....
wh79d160
I got a building permit. :hide: You need one for electrical? :D and water? :ychain: I better leave my gate locked. :D
Shuboxlover
I even needed one to install a freaking exhaust fan in the bathroom of the shed!!!!!! :ychain::D :D
Horse'n Around
What engine is that starter for? I have a starter for a K181 that is weak, i think it would need a set of brushes, it was on the Frankenhorse that my Dad left me. If its the right one, I could remove the part you need and send it to you for the cost of the postage. Let me know if it will help you and its yours. I would hate to see you have to buy a whole starter because one part is broken.Heck,you can have the whole starter for postage if it will help you.
John
Shuboxlover
WOW!!!! Thanks John :ychain::D
It's off a K341AS (16HP Kohler)
I got it started tonight, but with my starter off my D
My plan tomorrow night is to put the "bad" starter on and see what happens....
I will DEFINITELY let you know what i find out.
Thank-You :D :hide:
Scrumpy
Hey, I might be wrong but it is not the inside of the brush that hits the armature on these starters but the top of the brush. In this case the brush should still work although it may not stay "square" in the guide leading to accelerated wear. In the short run if needed it should get you through a storm but I would order a new set of brushes and call it good.
Scrump
edit for spelling error
Shuboxlover
For any of you who are wondering.....this did still work. JB welded magnet, broken brush.....you just can't keep them Kohlers down.... :banghead:
