KC9KAS 4,745 #1 Posted December 13, 2010 I have (2) 42" front plows, and both need new cutting edges. They are 42" long, 1/4" thick, and I am not sure of the width. If I make it 3", I should be able to go quite a long time before having to turn it over to use the other side. Any comments or suggestions? Thanks RS members! Share this post Link to post Share on other sites
Kelly 1,035 #2 Posted December 13, 2010 That is about the right size, new edges are on ebay about $35 Share this post Link to post Share on other sites
KC9KAS 4,745 #3 Posted December 13, 2010 Kelly, are you saying the 3" is the correct height? 42" wide, 3" tall and 1/4" thick? Share this post Link to post Share on other sites
harleyjj 2 #4 Posted December 14, 2010 I made mine 4"x42" out of 1/4" plate works great and should last a long time! cost me fifteen bucks at the local steel shop Share this post Link to post Share on other sites
KC9KAS 4,745 #5 Posted December 14, 2010 Thanks harleyjj.....4" it is! Hey....did you drill the mounting holes in the center of the 4" (2") so you can flip the cutting edge, or just eat up the cutting edge on one side? Share this post Link to post Share on other sites
harleyjj 2 #6 Posted December 15, 2010 I drilled the holes centered on it that way I can flip it when it wears down Share this post Link to post Share on other sites
wh79d160 52 #7 Posted December 15, 2010 I was told they are a hardned steel. Anyone know anything about that? Will the regular stuff work? I need 2 also. :ychain: Share this post Link to post Share on other sites
jimbotelho 1 #8 Posted December 15, 2010 Sure will!!! although the hardened steel is better it just means you may not get the longevity out of it Share this post Link to post Share on other sites
MalMac 1,333 #9 Posted December 15, 2010 If you use soft steel it will wear alot quicker than you think, plus you will be taking a chance of bending it and putting undo stress on the blade. How do I know this I tried it and had the edge bend ever so slightly back under the blade and caused small fractures around the bolt holes in the blade. This is just what happened to me. I had made mine the same dimisions as OEM. Also if you don't use carriage bolts and use regular hex head bolts you will round off the bolt and one heck of a time trying to remove them. Like I said this is my experince. Some on here might have had a good experince making homemade ones out of soft steel. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #10 Posted December 15, 2010 A strip of AR400 "wear plate" would be perfect. It's pretty popular for lining chutes in the aggregate industry, etc. Just don't go thinking the "el-cheapo" B&D drill bits from Wally-World will put a hole in it. Check with a local steel supply company or welding/fabrication shop or check out this website A cooperative, well-equipped welding/fab shop might even be able to punch the square holes for the carriage bolts. If not, it can be machined for countersunk socket head "screws". You'll just have to watch that you don't tie more money up in building a cutting edge than you'd have in buying a new OEM piece. Share this post Link to post Share on other sites
wh79d160 52 #11 Posted December 15, 2010 Talked to my neighbor. He said T1 is what I got. It's not the hardest, but will last a long time. It's = to grade 12 bolts or "cat bolts" I got a 7' x 4" x 1/4 this summer for my JD loader bucket (955) along w/end pieces. I think it was $40.00. I guess I'll go back & get two 42" x 3" x 1/4. Share this post Link to post Share on other sites
jimbotelho 1 #12 Posted December 15, 2010 tt is right on what I did was weld 2 pieces together making it a stronger bar I used blk cold rolled steel from homedepot and it will surely help rather than using a single piece of stock :D Share this post Link to post Share on other sites
bigblue12v 1 #13 Posted December 21, 2010 I have a 42" edge barely used i'll sell ya cheap. This blade wasn't used much and I upgraded the blade to 60" with a whole new edge the full width. Make an offer its yours. Has square holes for the carriage bolts. Share this post Link to post Share on other sites
KC9KAS 4,745 #14 Posted December 22, 2010 bigblue12v...you have a PM. Share this post Link to post Share on other sites
