520H4me 0 #1 Posted December 13, 2010 The hydraulic lift on my 520H is really weak to the point where it will not lift the snowblower attachment. The hydro pump must be ok as moves just fine. I really need to get this fixed. Anyone have any suggestions? Share this post Link to post Share on other sites
Shuboxlover 484 #2 Posted December 13, 2010 If it's a 2 stage, I would be MORE than happy to trade you my single stage for it....(It's alot lighter) just joking, I don't know what you problem might be, but I will watch this thread with much interest.... good luck. Share this post Link to post Share on other sites
buckeye 5 #3 Posted December 13, 2010 sounds like the seals in your cylinder are shot. Or the lift valve is bleeding off. Share this post Link to post Share on other sites
Kelly 1,037 #4 Posted December 13, 2010 Are you letting the tractor warm up? My 520's will not lift a thing in the cold for about 5 min. if not that check the fluid level,and if you don't have a leak, it could be the control valve. Share this post Link to post Share on other sites
520H4me 0 #5 Posted December 13, 2010 Thanks for the feedback guys. It is a single stage (sorry Shuboxlover). I have checked the lift capacity after warm up - there is no difference. Is there supposed to be a "helper spring" to help lift the blower? I have seen this on the two stage thrower. Share this post Link to post Share on other sites
Horse Fanatic 51 #6 Posted December 13, 2010 If everything is working properly, you do not need a helper spring for the hydro lift on your 520. Share this post Link to post Share on other sites
520H4me 0 #7 Posted December 14, 2010 So which typically goes bad first - the control valve or the seals in the hydraulic cylinder? I guess I will start by replacing the one that typically goes bad first, then will curse at myself for picking the wrong one! Thanks to everyone for your input. I have got to get this horse fixed before we get another 20" plus snowfall. :D Share this post Link to post Share on other sites
520H4me 0 #8 Posted December 15, 2010 Anyone have any feedback for me on this one? If you have had experience with this issue (weak hydraulic lift) which would you replace first - the control valve or the cylinder? Can either be rebuilt or do they need to be replaced? If I could get them rebuilt for a reasonable price I would get both done a the same time. I assume you need to bleed the system after replacing either so avoiding that would be a good thing... Share this post Link to post Share on other sites
kpinnc 17,154 #9 Posted December 15, 2010 Can either be rebuilt or do they need to be replaced? Both the valve and cylinder can be rebuilt. I'm not 100% sure about the cylinder, but the valve O-rings are still available. The valve rebuild is simple, because you just need to change the O-rings. It'll be much more work getting the valve removed and reinstalled on the tractor than anything else. I've never bought O-rings for the cylinder, but would imagine they are also available. If it were my tractor, I would rebuild the cylinder first. By it's location alone, it will be by far the easiest of the two to get to and rebuild- so long as the cylinder isn't one of the welded-together types. You may get lucky and not have to remove or rebuild the valve, which would make your repair much easier. And no, you should not need to bleed the system. The first couple "cycles" of the cylinder after rebuild should get all the air out. May take a couple minutes, but that's all. Share this post Link to post Share on other sites
520H4me 0 #10 Posted December 15, 2010 I live in Minnesota. We have "Fleet Farm" where you can buy new hydraulic cylinders. They are all too big for the 520H though. Anyone know where I could buy a replacement cylinder? It does not have to be a Wheelhorse part as long as it fits. Share this post Link to post Share on other sites
520H4me 0 #11 Posted December 15, 2010 Just checked the "Tractor Supply" website. They have a bunch of cylinders of various sizes at reasonable prices. Does anyone happen to know the bore and stroke of the cylinder on the 520H? I am at work or I would check it myself. Share this post Link to post Share on other sites
