Countdown To Christmas!
CTPATRIOT
310-8 questions???
CTPATRIOT
I can get a 310-8 with low compression pretty cheap.It comes with a deck and plastic/concrete wheel weights.I was told it's in decent shape(still have to see it).Does this have the same 8 speed as my C-120?Also,when did they come out with the plastic weights?
Kelly
Yes the trans will swap, not sure on the weights, a guess would be 80's
Sparky
It will probably have the slightly less heavy duty tranny with 1" axles. Still a good unit tho.
Mike........
CTPATRIOT
I forgot to ask,the deck will fit the older tractors too?The guy's asking $100-for all,i figured i could sell some of it,and keep some for spares.
Sparky
The attach-a-matic decks will fit either of your tractors except the 37"twin blade. It requires the use of 6" front rims for clearance which your C-120 does not have but the 310 should.
Mike.....
