CTPATRIOT 12 #1 Posted December 11, 2010 Is an 877 the same size tractor as a Commando 6??? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted December 11, 2010 Yes. Share this post Link to post Share on other sites
CTPATRIOT 12 #3 Posted December 11, 2010 Yes. Thanks.I thought so,just wanted to be sure.Not much room on those!!! Share this post Link to post Share on other sites
CTPATRIOT 12 #4 Posted December 12, 2010 Anybody have one of these?Would they be good for snowplowing,or is the engine a little small for the hydro trans? Share this post Link to post Share on other sites
clintonnut 127 #5 Posted December 13, 2010 I had an 876 but I thought it was a little weak with a 8hp kohler. A big block hydro such as a 1076 1077 1276 or 1277 is good for hard working such as snowblowing. 2-4 horse power makes huge difference with hydros. Charlie Share this post Link to post Share on other sites
jasoncracer 0 #6 Posted December 13, 2010 i had an 876 personally i thought it was a little under powered being an 8 hp with a hydro rear end :ychain: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #7 Posted December 13, 2010 They work absolutely fine at plowing snow as long as you keep in mind that they are only 8hp. The biggest thing you have to do is set the WOT (no-load) rpm up to about 3800-4000 so they only pull down to about 3400-3500 when they're working. You might not be able to shove a full 42" blade width in the heavier stuff, but it still beats the heck out of shoveling. Share this post Link to post Share on other sites
COMMANDO1 23 #8 Posted December 14, 2010 WHAT IF SOMEONE WERE TO PUT A 12 HORSE ON A COMMANDO.......HOW MUCH BETTER WOULD THAT BE? Share this post Link to post Share on other sites
kpinnc 16,277 #9 Posted December 14, 2010 WHAT IF SOMEONE WERE TO PUT A 12 HORSE ON A COMMANDO.......HOW MUCH BETTER WOULD THAT BE? About 4 hp better... :ychain: Share this post Link to post Share on other sites
