dgjks6 8 #76 Posted February 5, 2011 I got the cover on and the points on and gapped perfectly. Now for the head bolt question. The head has 7 bolts. 6 are 1 1/2inch 5/16-18. I got these brand new in a Grade 8. The seventh head bolt is 1 3/4. None of the stores have one. Can I use a 1 1/2? Oh - and where does the longer bolt go? It does not have a washer but an "L" shaped thing under it. Share this post Link to post Share on other sites
Duff 206 #77 Posted February 5, 2011 Greg, the "L-shaped" part is a lift point for taking the engine out with a hoist. I could tell you where it goes on an M-series but I'm not sure on your motor - sorry! Duff :thumbs: Share this post Link to post Share on other sites
jcb857 161 #78 Posted February 5, 2011 Is the L shape piece for supporting the starter :thumbs: Share this post Link to post Share on other sites
Anglo Traction 761 #79 Posted February 5, 2011 The Long bolt with the 'L' shaped plate goes in the Hole between the Exhaust Valve and the Cylinder bore. should be position Number 1 on the Head bolt tightening plan in the Manual. This is the nearest 'Point of Balance' for lifting the Engine out, the most metal and the need for a longer bolt. Share this post Link to post Share on other sites
dgjks6 8 #80 Posted February 5, 2011 Can I just use seven 1 1/2 inch bolts and leave it off? Share this post Link to post Share on other sites
Anglo Traction 761 #81 Posted February 5, 2011 Can I just use seven 1 1/2 inch bolts and leave it off? I suppose it's your call really, but as the 1 3/4" is there for the 'Lifting Eye' plate, replacing it with 1 1/2" bolt and washer should not create any adverse affect. Share this post Link to post Share on other sites
tunahead72 2,636 #82 Posted October 13, 2011 I'm thinking about tearing into one of my K241's this winter (haven't decided yet, just thinking), and I ran across this thread, and read pretty much every word. I found it very informative and entertaining, especially at 2:45 in the morning. I know an engine rebuild for many of you is a day job, but here at casa de Kovacevich I hope to have it done by early spring. This statement sums up where I'm at skill-wise on these things, so if I decide to pull mine apart, I fully expect to take at least as much time as you did. I just wanted to thank you and everybody who contributed to this project, I know I'll be back later to take another read, maybe when I'm more awake. But I have to ask, is it done yet? Does it run? :banghead: Share this post Link to post Share on other sites
dgjks6 8 #83 Posted October 14, 2011 Yep its done. Runs like a champ, but keeps running for a while when I turnthe key off. Going to recheck the timing. I restored the tractor to run the snowblower this winter, so its been siiting all summer waiting for action. Share this post Link to post Share on other sites
tunahead72 2,636 #84 Posted October 14, 2011 :banghead: Except for the run-on, that is. <_< Maybe a stray piece of carbon or something in the combustion chamber? Let us know how it turns out after you adjust the timing. :thumbs2: Share this post Link to post Share on other sites
